Help make Ilogic for dxf export work.
Message 1 of 38
I have been working on making an Ilogic rule to create dxf's of all sheet metal parts with the Vendor "LASER" in an assembly and then export and sort them based on thickness and material.  @kevinv has done most of the work on the rule and it runs on his end using Inventor 2020 but for me using Inventor Pro 2018 there is no error code but it doesn't create the files.  If anyone using Inventor 2018 could try to help make it work that would be greatly appreciated.
Replies (37)
Message 2 of 38
Sergio.D.Suárez
Hi, I think the error is in the equality where it is detailed in red. I have Inv 2018 and it has worked for me.
Sub Main()
    Dim New_Folder_Path As String = ThisDoc.Path
    Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    My.Computer.FileSystem.CreateDirectory(New_Folder_Path)
    'Ask user for REV level
    Dim Rev_Level As String = ""
    Rev_Level = InputBox ("Enter Rev Level","Creating DXF files For Entire Assembly")
    Dim Count_up As Integer = 0
    Dim Gauge_Folders(12) As String
    Dim Ga As String
    Dim doc As Document
	Dim R_Part As String
	Dim oMaterial As Material
    For Each doc In oAsmDoc.AllReferencedDocuments
        If doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			Try
				R_Part = doc.DisplayName
				oMaterial = doc.ComponentDefinition.Material
				Gauge_Path = New_Folder_Path & "\" & Parameter(R_Part, "Thickness") & " " & oMaterial.Name
					If UCase(iProperties.Value(R_Part, "Project", "Vendor")) = "LASER" Then	' If doc.PropertySets.Item("Design Tracking Properties").Item("Vendor").Value= "LASER" Then
						Try
							My.Computer.FileSystem.CreateDirectory(Gauge_Path)
						Catch
						End Try
		            	Call Make_DXF(doc, Rev_Level, Gauge_Path)
			Catch
			End Try
    Next
MsgBox("DXF Export Complete",,"All Done")
End Sub
Sub Make_DXF(doc As Document, Rev_L As String, File_Location As String)
    Dim oSheetMetalCompDef As SheetMetalComponentDefinition
    oSheetMetalCompDef = doc.ComponentDefinition
    Dim Part_Name As String = doc.DisplayName
    Dim TestPos As Integer = 0
    ' Create flat pattern if none
    If Not oSheetMetalCompDef.HasFlatPattern = False Then
        ' Open document
        openDoc = ThisApplication.Documents.Open(doc, False)
        ' Unfold part
        oSheetMetalCompDef.Unfold()
        ' Exit flat pattern
        oSheetMetalCompDef.FlatPattern.ExitEdit()
        ' Close document
        openDoc.Close()
        Dim Rev_Adder As String = ""
        If Rev_L <> "" Then Rev_Adder = " REV " & Rev_L
        TestPos = InStr(1, Part_Name, ".")
        If TestPos <> 0 Then
            Part_Name = Left(Part_Name, InStr(Part_Name, ".")-1)
        Dim New_Name As String = Part_Name
        Dim nameandpath As String = File_Location & "\" & New_Name & Rev_Adder & ".dxf"
        Dim oDataIO As DataIO = doc.ComponentDefinition.DataIO
        oDataIO.WriteDataToFile("FLAT PATTERN DXF?AcadVersion=R12&RebaseGeometry=True&SimplifySpline=True&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL&SplineToleranceDouble=0.01",nameandpath)
End Sub
 I have removed some lines of code that were unnecessary.
I hope it helps to solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 38
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please provide sample input assembly and expected output dxf files with folder structure (Sorted thickness and material) ? Which are exported through manual tasks.
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 38
kevinv
If you change that to [= False] the you should probably remove the [Not] at the beginning of that line
Message 5 of 38
Sergio.D.Suárez
You're right, but I do not know why, but it works like that. Here you have another code that should work
Sub Main()
    Dim Ga As String
    Dim doc As Document
			Try
						Try
						Catch
						End Try
			Catch
			End Try
    Next
End Sub
		If oSheetMetalCompDef.HasFlatPattern = False Then
			oSheetMetalCompDef.Close
End Sub
Mechanical Designer
Message 6 of 38
kevinv
I agree with that edit, thanks for stepping up and helping out!
Message 7 of 38
I don't know why but it still doesn't create any files for me.  I have a VBA macro that works though.  I'll attach it in case anyone wants that instead.
Message 8 of 38
bradeneuropeArthur
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 9 of 38
It only creates them for sheet metal parts with the Vendor "LASER" if you're talking about the macro.  If you meant the Ilogic Rule it doesn't create any for me either.
Message 10 of 38
GICain
You may want to try this DXF Exporter app. I've had this implemented in the department I work in and have been mostly happy with it.
Takes a little getting used to but you can export sheet metal dxf's of an entire assembly in a matter of seconds once set up is complete.
You can also write your own filename extension however you want it to read. The only downside is it only pulls from a select default Inventor parameters and currently custom iProperties can't be used.
Screenshot of final result attached.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=7498862835390395853&appLang=en&os=Win32_64
Gabe Cain
Structural Designer/Engineering Checker
Message 11 of 38
bsnyderACLUW
used the VBA macros to make this work for Ilogic.
just hade to get rid of a few things and add some ()'s and voila it works!!!!
Sub main (Export_Sheetmetal())
    'define the active document as an assembly file
     oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmName As String
    oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName))
    'check that the active document is an assembly file
    If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
        MsgBox ("Please run this rule from the assembly file.")
        Exit Sub
    'get user input
    Result = MsgBox("This will create a DXF file for all of the asembly components that are sheet metal." _
    & vbLf & "This rule expects that the part file is saved." _
    & vbLf & " " _
    & vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
    & vbLf & "This could take a while.", vbYesNo, "iLogic  - Batch Output DXFs ")
    If Result = vbNo Then
        Exit Sub
    Dim oPath As String
    Dim iSplit As Integer
    iSplit = InStrRev(oAsmDoc.FullDocumentName, "\")
    oPath = Left(oAsmDoc.FullDocumentName, iSplit - 1)
    Dim oDataMedium As DataMedium
     oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    Dim oContext As TranslationContext
     oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oOptions As NameValueMap
     oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    'get DXF target folder path
    Dim oFolder As String
    oFolder = oPath & "\" & oAsmName & " DXF Files"
    'Check for the DXF folder and create it if it does not exist
    If Len(Dir(oFolder, vbDirectory)) = 0 Then
        MkDir (oFolder)
    '- - - - - - - - - - - - -Component  - - - - - - - - - - - -
    'look at the files referenced by the assembly
    Dim oRefDocs As DocumentsEnumerator
     oRefDocs = oAsmDoc.AllReferencedDocuments
    Dim oRefDoc As Document
    Dim iptPathName As String
    'work the drawing files for the referenced models
    'this expects that the model has been saved
    For Each oRefDoc In oRefDocs
        If oRefDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            If oRefDoc.PropertySets.Item("Design Tracking Properties").Item("Vendor").Value = "" Then
                Dim oDrawDoc As PartDocument
                 oDrawDoc = ThisApplication.Documents.Open(oRefDoc.FullDocumentName, False)
                Dim oDef As SheetMetalComponentDefinition
                 oDef = oDrawDoc.ComponentDefinition
                Dim oThick As String
                oThick = oDef.Thickness.Value
                 Select Case oThick
                    Case 0.635
                         Gauge_Name = "0.25"
                    Case 0.1524
                        Gauge_Name = "16 Gauge"
                    Case 0.1905
                        Gauge_Name = "14 Gauge"
                    Case 0.3048
                        Gauge_Name = "11 Gauge"
                    Case 0.9525
                        Gauge_Name = "0.375"
                    Case 0.475996
                        Gauge_Name = "7 Gauge"
                    Case Else
                        Gauge_Name = "Other"
                End Select
                Dim oMaterial As String
                oMaterial = oDrawDoc.ActiveMaterial.DisplayName
                oFolder = oPath & "\" & oAsmName & " DXF Files\" & Gauge_Name & "-" & oMaterial
                    MkDir (oFolder)
                oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
                'Set the DXF target file name
                oDataMedium.FileName = oFolder & "\" & oFileName & ".dxf"
                Dim oCompDef As SheetMetalComponentDefinition
                 oCompDef = oDrawDoc.ComponentDefinition
                If oCompDef.HasFlatPattern = False Then
                    oCompDef.Unfold
                Else
                    oCompDef.FlatPattern.Edit
                Dim sOut As String
                sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
                Call oCompDef.DataIO.WriteDataToFile(sOut, oFolder & "\" & oFileName & ".dxf")
                oCompDef.FlatPattern.ExitEdit
                oDrawDoc.Close
    Next
End Sub
Message 12 of 38
reine_den_andra
Hi
I'm not good at ilogic rules. Is it just to copy and paste this code into "Add rule"? I got an error message ....
Message 13 of 38
kevinv
What post are you grabbing the code from? There are a number of them above with different tweaks. The first code I see when I scroll up has some folder names in it that would need to be changed in order to match your file structure. Some of the other code above places the dxf files in the same place as the assembly. You might want to try one of those. Otherwise you will have to be more specific with what errors you are getting.
Message 14 of 38
kevinv
I think the best code to grab is found here:
Solved: Re: Ilogic - Batch dxf from Assembly - Autodesk Community - Inventor
The code is in message 17. The only change you should have to make is the folder path at the beginning. change
"G:\DXF\Production\"
to whatever location you want the DXFs to go. Good luck!
Message 15 of 38
reine_den_andra
Hi
I have inventor 2019.
Is it possible to make a rule so that you can get a DXF from a part to a specific folder?
This is just about sheet metal.
Option 1: If I only have one part open.
Option 2: From an assembly.
Or if it is possible to have these at the same time?
I saw your link. Is it just to copy and paste into the add rule? I get an error message that I do not understand.
"Error in rule: Rule4, in document: part5.ipt
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.AssemblyDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D465-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: Gränssnittet stöds inte (Exception from HRESULT: 0x80004002 (E_NOINTERFACE))."
Message 16 of 38
kevinv
Thank you for the error message. The code you are using is only for an assembly file. I think the error is happening because you are running it on a part file. There may also be issues with file locations. Let me know what path you want the DXFs to land in and I will try to send you some code that will work for you, for both parts and assembles.
Message 17 of 38
reine_den_andra
Thanks for all the help with this.
We can take "C: \ DXF" only as an example in this case.
I know of course that it's just "Export Face As ..." on a flat pattern, but it would be quick and easy if there was a rule to do this.
I want to be able to export dxf if I may only have one part open or maybe one assembly open.
Another thing I do not understand. If you have made a rule, then it does not remain if you open something else?
How do I get it to always be in the program no matter what I open? I have another rule that is the same.
Message 18 of 38
kevinv
Over time I added features to this code that are not mentioned here in this thread. What I am posting below is a version of the code that I just simplified for you. This will work for both part files and assemblies. First thing it does is save what you are working on. Then it will ask if you want to run the rule, then ask for a revision level(you can leave that blank-just hit OK), then confirm the path for you before creating the dxf files. It will delete any previous DXFs for each file and add the material gauge to the start of the file name for sorting purposes.
Before I post the code let me answer your second question. In order to have the rules available to all of your files you need to set up external rules. To do that open iLogic Configuration:
and then add a new External Rule Directory:
Once you have done that you will see the folder show up under external rules. Any rules you create in there will be available from all of your files. If you have other users you can put that folder on a server drive and map the external directory to the same folder on the other computers. Mine looks like this:
Here is the code, note the one place you will need to update the path if you want to change it is right after Gauge_Path  =
Sub Main()
	 ThisApplication.[_LibraryDocumentModifiable] = True
	Dim oDoc As Document
	Dim Job_confirm As String
	Dim Ga As String
	Dim JobNum As String = iProperties.Value("Project", "Project")
	Dim DXFPath As String
	Dim Purchased As Boolean = False
	Dim Gauge_Path As String
'AutoSave before rule changes anything
Try
	SaveMe = ThisDoc.Document
	SaveMe.Save
Catch
	SaveQ=MsgBox("Save did NOT happen. Do you want to run the rule anyway?",vbYesNo,"Something Went Wrong")
	If SaveQ=7 Then Exit Sub
End Try
'^^^^EDIT PATH BELOW^^^^^^^^^^^^^^
Gauge_Path = "C:\DXF\"
		oDoc = ThisDoc.Document
	If oDoc.DocumentType = kPartDocumentObject Then
'%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%CODE FOR PART DXF - NOT ASSEMBLY%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
		If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
			Job_confirm = MsgBox ("Sending File to DXF Folder " & Gauge_Path, vbOKCancel, "Confirm Path")
			If Job_confirm = "2" Then Exit Sub
			Rev_Level = InputBox("Enter Rev Level", "Creating DXF file for Single Part")
				'ThisApplication.ActiveDocument.BOMSTRUCTURE
				Dim oPrtCompDef As PartComponentDefinition
				oPrtCompDef = ThisApplication.ActiveDocument.ComponentDefinition
				'MsgBox(oPrtCompDef.BOMStructure)
				'Exit Sub
	            'set it to the current document
	            oSheetMetalCompDef = oDoc.ComponentDefinition
	            'Dim oStyle As SheetMetalStyle
	            Ga = oSheetMetalCompDef.ActiveSheetMetalStyle.Name
					'remove quotes and replace / in fractions with _
				Ga = Replace(Ga, "/", "_")
				Ga = Replace(Ga, Chr(34), "")
				Job_confirm = MsgBox ("Sending File to DXF Folder " & Gauge_Path ,vbOKCancel, "Confirm Path")
'MsgBox(Len(Gauge_Path))
				Try
					Call Make_DXF(oDoc, Rev_Level, Gauge_Path)
				Catch
					MsgBox(Gauge_Path,,"Can't create folder:")
				End Try
		Exit Sub	'stop code after part level export
'%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%END CODE FOR PART DXF - NOT ASSEMBLY%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
	ElseIf oDoc.DocumentType = kAssemblyDocumentObject Then
		'Correct doc type - now move on
	ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
		MsgBox("This is Not the Correct Rule",,"Ending Run")
		Exit Sub
'Dim oAsmDoc As AssemblyDocument
Dim doc As Document
Job_confirm = MsgBox ("Sending Files to DXF Folder " & Gauge_Path, vbOKCancel, "Confirm Path")
'MsgBox(Job_confirm,,"job_confirm")
Dim Gauge_Folders(40) As String
Count_up = 0
'Now we loop through all of the parts checking for sheetmetal parts and creating DXF files
'oAsmDoc = ThisApplication.ActiveDocument
	Try
		Count_up = Count_up + 1
	Catch
		MsgBox(doc.FullDocumentName)
	End Try
	Next
End Sub
'''-----MAKE DXF-----MAKE DXF-----MAKE DXF-----MAKE DXF-----MAKE DXF-----MAKE DXF-----MAKE DXF-----MAKE DXF-----MAKE DXF-----MAKE DXF-----MAKE DXF-----MAKE DXF
			Dim GA_Adder As String = oSheetMetalCompDef.ActiveSheetMetalStyle.Name
'Dim GA_Adder As String = iProperties.Value(doc.DisplayName, "Custom", "GAUGE")
			GA_Adder = Replace(GA_Adder, "/", "_")
			GA_Adder = Replace(GA_Adder, Chr(34), "")
			GA_Adder = Replace(GA_Adder, "%", "")
			GA_Adder = Replace(GA_Adder, ".", "")
oCompDef = doc.ComponentDefinition
	'checking for parts that don't have flat pattern and telling user what parts are skipped for lack of flat pattern
		MsgBox ("Skipping DXF file for:" & vbNewLine & vbNewLine & Part_Name, ,"Flat Pattern Missing")
	Else
		'Checking to be sure the name passed to sub has a . in it
		'trimming everything before the .
		If TestPos <> 0 Then Part_Name = Left(Part_Name, InStr(Part_Name, ".")-1)
''		'*******************remove line below to remove gauge from file name***********
		Part_Name = GA_Adder & " " & Part_Name
''		'*******************remove line above to remove gauge from file name***********
		'Creating Rev add-on for file name if needed
		'^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^CHECKING FOR AND DELETING OLD DXF FILES^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
		Dim Old_Files As String = ""
		'Dim Delete_List(5) As String
		'Dim q As Integer = 0
		Old_Files = Dir(File_Location & "\" & Part_Name & "*")
		Do Until Old_Files = ""
			Try
				Kill(File_Location & "\" & Old_Files)
			Catch
				MsgBox("Could Not Delete:"  & vbNewLine & vbNewLine & File_Location & "\" & Old_Files,,"Delete Error")
			End Try
			Old_Files = Dir()
		Loop
		'^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^END CHECKING FOR AND DELETING OLD DXF FILES^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
		Dim nameandpath As String = File_Location & "\" & Part_Name & Rev_Adder & ".dxf"
		nameandpath = File_Location & "\" & Part_Name & Rev_Adder & ".dxf"
		'MsgBox(nameandpath)
		'Create the DXF file now!
		Try
		Catch
			MsgBox (nameandpath,,"Error on this file")
		End Try
End Sub
Message 19 of 38
kevinv
Looks like I replied to the wrong message, see my answer in reply to Eric
Message 20 of 38
reine_den_andra
Hi
"Once you have done that you will see the folder show up under external rules"
Where do I find this?
EDIT: I found. I understand. I've never done this before.
