Help debug this IF statement Please :)
frahaman7SKBG
Message 1 of 9
frahaman7SKBG
Can someone help me debug this code? I could not for the life of me figure out why this 'if statement' won't work
I have checked the output value of 'Ang2'  through the 'Z2' output in the parameter and have confirmed that it is in fact equal to 90. So I can't figure out why the code thinks the "sharedVariable("Ang2")" does not equal 90 when in fact it does.
I added the ipt part model to this code that is being tested.
Dim oParams As Parameters
oParams=ThisDoc.Document.ComponentDefinition.Parameters
Dim oUserParams As UserParameters
oUserParams=oParams.UserParameters
sharedVariable("A") = Measure.ExtentsLength
sharedVariable("B") = Measure.ExtentsWidth
sharedVariable("C") = Measure.ExtentsHeight
sharedVariable("Ang1") = Measure.Angle("Large Face", "XZ Plane")
sharedVariable("Ang2") = Measure.Angle("Large Face", "XY Plane")
sharedVariable("Ang3") = Measure.Angle("Large Face", "YZ Plane")
X1 = sharedVariable("A")
X2 = sharedVariable("B")
X3 = sharedVariable("C")
Z1 = sharedVariable("Ang1")
Z2 = sharedVariable("Ang2")
Z3 = sharedVariable("Ang3")
If sharedVariable("Ang1") >=0  And sharedVariable("Ang2") = 90  Then
	Try
	oUserParams("G_L").Value = (sharedVariable("A")/Cos(sharedVariable("Ang1")*PI/180)*2.54)
	Catch
	' assume error means not found and create it
	oUserParams.AddByValue("G_L", (sharedVariable("A")/Cos(sharedVariable("Ang1")*PI/180)*2.54), kInchLengthUnits)
	End Try
Else
iLogicVb.UpdateWhenDone = True
Replies (8)
Message 2 of 9
A.Acheson
Just an initial guess is that measure.area would be system units of radians and your looking to check that value against a degree value. Haven't tested this but perhaps you can check.
Regards
Alan
Message 3 of 9
frahaman7SKBG
That was my fist assumption too, but it doesn't look like it. Check it against both radian and degree.
Message 4 of 9
frahaman7SKBG
BTW if I change the 'Ang2' with 'Z2' in the if statement, the code works as expected. Can't figure out why it won't work with 'Ang2'
Message 5 of 9
S.Hørup
I am not able to use the part you have attached, so can't test it properly.
My initial thought is that the meassurement is not exactly 90°- but perhaps 90.00001° - then the if statement is not true.
As a test, you can try set Ang2 to this:
sharedVariable("Ang2") = Measure.Angle("YZ Plane", "XY Plane")
then you are absolutely sure it is 90°
Next,I would first try changing the IF-statement to
If sharedVariable("Ang1") >=0  And Round(sharedVariable("Ang2")) = 90  Then
Message 6 of 9
frahaman7SKBG
Hi @S.Hørup ,
Thanks for your suggestion. In both cases, the code seems to work as expected.
I have checked the value up to 8 decimal places for the Ang2, and it gives 90.00000000. So I still don't understand why the code won't work as is without the rounding function.
Message 7 of 9
S.Hørup
Hi again, now I got to test it with your part as well.
This code works:
If sharedVariable("Ang1") >= 0 And Round(sharedVariable("Ang2"),13) = 90 Then
	MsgBox("Both statements are true")
	Try
	Catch
	End Try
Else
 As you see, I round with 13 digits - Then the code works fine. If I change the round-function to 14, the code fails.
But every time I want to see the value of Ang2 I also only see trailing zeros.
Edit: Could the issue be in the precision of the data types?
Message 8 of 9
JelteDeJong
Precision problems with floating point variables are common. At least so common that Microsoft wrote a page about it. And Autodesk iLogic made a special function for comparing floating point variables. "DoublesAreEqual(... ...)"
try it like this:
If sharedVariable("Ang1") >= 0 And DoubleUtil.DoublesAreEqual(sharedVariable("Ang2"),90) Then
	Dim val = sharedVariable("A")/Cos(sharedVariable("Ang1")*PI/180)*2.54
	Try
		oUserParams("G_L").Value = val
	Catch
		oUserParams.AddByValue("G_L", val, kInchLengthUnits)
	End Try
Jelte de Jong
Blog: hjalte.nl - github.com
Message 9 of 9
frahaman7SKBG
Thanks for the insight on this issue.
