I've done some searching and tried playing with iLogic but haven't had much success yet.
We need to identify the manufacture process of our parts so that purchasing know which suppliers to contact. For example it could be Cut, Folded or Rolled. We need to do this for hundreds of parts, so the idea I've had to make this as painless as possible is to manually sort each part into Cut/Folded/Rolled folders in the model tree and then run an iLogic rule that will run for all parts in the assembly to create a custom iProperty called "Process" with the value as the folder name that part is in.
Is anyone able to point me in the right direction to achieve this? I'm also open to other suggestions if someone has a better way to handle a similar situation.
Most iLogic I've created before is manipulating parameters and component rules so I'm struggling to understand what I've read so far about how to target assembly tree folders.
