variables to parameters
anavazquez5LRNJ
anavazquez5LRNJ
How can I pass variables from visual basic.net to inventor?
I would like to change the width and length of any part from a form in vb.net, I would appreciate if you could guide me.
Lucas.dolinarVFXZU
you won't even need code to do that...
do you know about the Forms? in the ilogic tab, subtab: Form / global form >RMB> create new form
you can add parameters to this form.
marcin_otręba
yiou can do it trough:
oDoc.ComponentDefinition.parameters.UserParameters.Item("height").Expression = "height-10mm"  'valid parameter name must be enter
or
oDoc.ComponentDefinition.parameters.UserParameters.Item("height").value = 245 ' adjust to correct inventor unit.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
