help, create an ordinateset on drawing
dhanna
Message 1 of 8
dhanna
good afternoon,
Trying to collect hole centers from 2 drawing views  and add an ordinate set either up or down based on location of holes on view.
this causes the error:
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.OrdinateDimensionSets.Add(ObjectCollection GeometryIntents, Point2d PlacementPoint, DimensionTypeEnum DimensionType, Object DimensionStyle, Object Layer)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
<code>
Dim inv = ThisApplication
Dim oDoc = ThisDrawing.Document
Dim  cnt As Long
Dim cursht As Inventor.Sheet
Dim Jndx As Long
Dim oVw As Inventor.DrawingView
Dim oDcrv As Inventor.DrawingCurve
'On Error Resume Next
Dim oTG As Inventor.TransientGeometry = inv.TransientGeometry
Dim gIntent As Inventor.GeometryIntent
For Jndx = 30 To 31 '87
		Dim oUpr As Inventor.ObjectCollection = inv.TransientObjects.CreateObjectCollection
		Dim oLwr As Inventor.ObjectCollection = inv.TransientObjects.CreateObjectCollection
			cursht = oDoc.Sheets(Jndx)
Dim oviews As Inventor.DrawingViews = cursht.DrawingViews
				oVw = oviews(2)
						For Each oDcrv In oVw.DrawingCurves
							If oDcrv.CurveType = CurveTypeEnum.kCircleCurve Then
								gIntent = cursht.CreateGeometryIntent(oDcrv.CenterPoint)
 										If gIntent.Geometry.Y >=  oVw.Position.Y  Then
											oUpr.Add(gIntent)
											Else
												oLwr.Add	(gIntent)
										End If
							End If
						'MessageBox.Show(cnt,oVw.Name)
					Next   ' 'oDcrv
				If oUpr.Count >1 Then
					''MessageBox.Show(OUPR(1).GEOMETRY.X & ", " & oVw.Position.Y + oVw.Height + 3, " UPPER pOSITION")
					cursht.DrawingDimensions.OrdinateDimensionSets.Add(oUpr, _
							oTG.CreatePoint2d(oUpr(1).GEOMETRY.X, oVw.Position.Y + oVw.Height ), _
							DimensionTypeEnum.kVerticalDimensionType)
				End If
					If oLwr.Count >1 Then
						''MessageBox.Show(OUPR(1).GEOMETRY.X & ", " & oVw.Position.Y - oVw.Height - 3, "LOWER pOSITION")
						cursht.DrawingDimensions.OrdinateDimensionSets.Add(oLwr, _
									oTG.CreatePoint2d(oLwr(1).GEOMETRY.X, oVw.Position.Y - oVw.Height ), _
					End If
oVw = oviews(5)
					oLwr.Clear
												oLwr.Add	(gIntent)
							End If
					Next   ' 'oDcrv
Next   'Jndx
<\code>
Replies (7)
Message 2 of 8
dalton98
Hello. I would recommend you look at the sample program for creating ordinate dimensions.
Top right inventor program > (?) icon > Help > Programming/ API Help
Then search "Create ordinate dimension API Sample" > Sample Programs > Drawings > "Create Ordinate Dimension"
Also, I understand your though process on wanting to create the dimension above/ below the view based on the hole position, but in your drawing the holes are vertically aligned, so you want two dimensions for the same position? What if the hole is centered and doesn't favor top/bot? Just some thoughts
Message 3 of 8
dhanna
Good morning;
            Thanks for the reply, however, I do not see in the sample where I went wrong. True, the holes look to be vertically aligned, yet most will not be and only a little out of  alignment thus the upper and lower  divide to ordinate sets.
The following error occurs
at ThisRule.Main()
when it gets to the 'add'.
I've changed it up a bit to see if I could get the error to pop where I could find it, as such
<code>
 Dim tmppnt As Inventor.Point2d = oTG.CreatePoint2d(oUpr.Item(1).GEOMETRY.X, oVw.Position.Y + oVw.Height)
 MessageBox.Show(oUpr.Item(1).GEOMETRY.X & ", " & oVw.Position.Y + oVw.Height + 3, " UPPER pOSITION")
cursht.DrawingDimensions.OrdinateDimensionSets.Add(oUpr, tmppnt, DimensionTypeEnum.kVerticalDimensionType)
End If
Dim tmppnt As Inventor.Point2d = oTG.CreatePoint2d(oLwr.Item(1).GEOMETRY.X, oVw.Position.Y - oVw.Height )
MessageBox.Show(oUpr.Item(1).GEOMETRY.X & ", " & oVw.Position.Y + oVw.Height + 3, " lower pOSITION")
cursht.DrawingDimensions.OrdinateDimensionSets.Add(oLwr, tmppnt, DimensionTypeEnum.kVerticalDimensionType) End If
<\code>
Message 4 of 8
dhanna
this is an example of what I'm attempting to setup
Message 5 of 8
dalton98
You cant place all ordinate dimensions with one command, you will need to do each individual one. Ex.
For i = 1 to oUpr.Count
cursht
.DrawingDimensions.OrdinateDimensionSets.Add(oUpr(i), tmppnt, DimensionTypeEnum.kVerticalDimensionType)
Next
Message 6 of 8
dhanna
I get the following error with that change:
System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.ObjectCollection'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{6939FFDD-BA10-11D2-B779-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
at ThisRule.Main()
also, the 2018 API Help DrawingDimensions.OrdinateDimensionSets.Add method shows an object collection of GeometryIntents
OrdinateDimensionSets.Add( GeometryIntents As ObjectCollection, PlacementPoint As Point2d, DimensionType As DimensionTypeEnum, [DimensionStyle] As Variant, [Layer] As Variant )
 could it be because I didn't specify dimensionstyle or layer optionals from an external rule?
the rule with the recommended change:
<code>
Dim  cnt As Long
Dim Jndx As Long
For Jndx = 33 To 33 '87
oVw = oviews(2)
MessageBox.Show(gIntent.Geometry.y.tostring,oVw.Position.Y.ToString)
oUpr.Add(gIntent)
Else
oLwr.Add	(gIntent)
End If
End If
Next   ' 'oDcrv
'MessageBox.Show(oUpr.Count,oLwr.Count)
'cursht.DrawingDimensions.OrdinateDimensionSets.Add(oUpr,tmppnt, DimensionTypeEnum.kVerticalDimensionType)
For i = 1 To oUpr.Count
cursht.DrawingDimensions.OrdinateDimensionSets.Add(oUpr(i), tmppnt, DimensionTypeEnum.kVerticalDimensionType)
Next
End If
'cursht.DrawingDimensions.OrdinateDimensionSets.Add(oLwr, tmppnt, DimensionTypeEnum.kVerticalDimensionType)
For i = 1 To oLwr.Count
cursht.DrawingDimensions.OrdinateDimensionSets.Add(oLwr(i), tmppnt, DimensionTypeEnum.kVerticalDimensionType)
Next
End If
oVw = oviews(5)
oLwr.Clear
oLwr.Add	(gIntent)
End If
Next   ' 'oDcrv
Next   'Jndx
<\code>
Message 7 of 8
dalton98
Oh ok I misunderstood. I got it to work for me by changing 2 things:
gIntent = cursht.CreateGeometryIntent(oDcrv, kCenterPointIntent)
'changing oUpr.Item(1).Geometry.X to oUpr.Item(1).PointOnSheet.X
'its a good habit to always define the objects you are working with so i defined
the ordinate dimension set
'also ordinate set dimensions are opposite of what the are so kVerticalDimensionType changes
to kHorizontalDimensionType
 Here is the code I altered and got to work:
Dim  cnt As Long
Dim Jndx As Long
cursht = oDoc.ActiveSheet
oVw = oviews(1)
'If gIntent.Geometry.Y >=  oVw.Position.Y  Then
oUpr.Add(gIntent)
'Else
'oLwr.Add	(gIntent)
'End If
End If
Next   ' 'oDcrv
Dim tmppnt As Inventor.Point2d = oTG.CreatePoint2d(oUpr.Item(1).PointOnSheet.X, oVw.Position.Y + oVw.Height)
'MessageBox.Show(oUpr.Item(1).GEOMETRY.X & ", " & oVw.Position.Y + oVw.Height + 3, " UPPER pOSITION")
Dim ordSet1 As OrdinateDimensionSet
ordSet1 = cursht.DrawingDimensions.OrdinateDimensionSets.Add(oUpr, tmppnt, DimensionTypeEnum.kHorizontalDimensionType)
End If
Message 8 of 8
dhanna
 Thank you so very much. That got me to where I needed to be.  I hadn't even looked at pointonsheet. in the docs.
