Hatching will not change color.
JBEDsol
JBEDsol
For a long time I would show cutouts w/ hatching.  Add a sketch, make a hatch, then alter the style/color to red.  For some reason the past few weeks I've noticed I can't do this.  It tends to work sometimes but others not and I've no idea why the color won't change.  Is there a setting or something I need to change?  I even changed the default hatch layer to red and nothing.
bradeneuropeArthur
You mean this:
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JBEDsol
Exactly, however when I update the hatch color to red, nothing changes. I go to my layers and change the hatch layer to red, still nothing.
Bellmer-CAD-Admin
Hello Guys,
I have a similar issue: I want to Change the Color of a hatch region, that has a certain hatch pattern. For the HatchRigion.Color-Object, we have a Method that calls "SetColor(Red as Byte, Green as Byte, Blue as Byte)" available.
I was happy to found this:
https://forums.autodesk.com/t5/inventor-programming-ilogic/accessing-quot-edit-hatch-pattern-quot-in...
I took it and customized it for my usecase, ended up with this:
(you can ignore the Plasibility Test - which was postiv btw)
	oDDoc = ThisDrawing.Document
	oSheet = oDDoc.ActiveSheet
	For Each oView As DrawingView In oSheet.DrawingViews
		If oView.ViewType = DrawingViewTypeEnum.kSectionDrawingViewType Then
			Dim oSView As SectionDrawingView = oView
			For Each oHatchR As DrawingViewHatchRegion In oSView.HatchRegions
				'check pattern type for concrete
				If oHatchR.Pattern.Name = "AR-CONC"
					oHatchR.Color.SetColor(192, 192, 192)
'					' Plausibility test for access to the HatchRegion-Object:
'					If oHatchR.DoublePattern = True
'						oHatchR.DoublePattern = False
'					Else
'						oHatchR.DoublePattern = True
'					End If
			Next
	Next
My Problem: the SetColor-Method does nothing...
Doing the job manually is like:
What did I do wrong? Do I have to assign sth like a Color-Object to oHatchR.Color, to overwrite it, instead of just giving the RGB-Values?
(I am working with Inventor 2023.5.2)
Thanks for your help so much in advance
BR Raphael
Ivan_Sinicyn
@Bellmer-CAD-Admin
Sub Main()
    ' Get the active drawing document
    Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
    If oDDoc Is Nothing OrElse oDDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
        Exit Sub
    ' Get the active sheet
    Dim oSheet As Sheet = oDDoc.ActiveSheet
    ' Iterate through all views on the sheet
            ' Iterate through hatch regions in the section view
                ' Check pattern type for concrete
                If oHatchR.Pattern.Name = "AR-CONC" Then
                    ' Create a new color object and assign it
                    Dim oColor As Color = ThisApplication.TransientObjects.CreateColor(192, 192, 192)
                    oHatchR.Color = oColor
            Next
    Next
End Sub
INV 2025.3
Bellmer-CAD-Admin
Hi Ivan,
thanks a lot! Works perfekt!
BR
Raphael
