Grouped Custom Commands in Context Menu
spencer
Message 1 of 10
spencer
Hopefully there's a simple answer for this, but I'm trying to make a group of commands in the context menu but haven't had any luck. Doing everything through a VB.NET addin, commands are being added just fine on their own but I wanted to group some of that were related to each other (ie. a main command and come copies with different arguments).
Really I want it to be like the Component drop-down shown.
Any suggestions?
Replies (9)
Message 2 of 10
bradeneuropeArthur
Could you post your code that you are having that far?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
spencer
The entirety has a lot going on, but the important bits are like this:
'Stuff
Private WithEvents OriginConstrainCmd As Inventor.ButtonDefinition Private WithEvents OriginConstrainCmdNX As Inventor.ButtonDefinition Private WithEvents OriginConstrainCmdNY As Inventor.ButtonDefinition Private WithEvents OriginConstrainCmdNZ As Inventor.ButtonDefinition
'More stuff
OriginConstrainCmd = objControlDefs.AddButtonDefinition("Origin Constrain", "OriginConstrainCmd", CommandTypesEnum.kQueryOnlyCmdType,,, "Constrains origins of selected parts to first selection.")
OriginConstrainCmdNX = objControlDefs.AddButtonDefinition("Exclude X Plane", "OriginConstrainCmdNX", CommandTypesEnum.kQueryOnlyCmdType,,, "")
OriginConstrainCmdNY = objControlDefs.AddButtonDefinition("Exclude Y Plane", "OriginConstrainCmdNY", CommandTypesEnum.kQueryOnlyCmdType,,, "")
OriginConstrainCmdNZ = objControlDefs.AddButtonDefinition("Exclude Z Plane", "OriginConstrainCmdNZ", CommandTypesEnum.kQueryOnlyCmdType,,, "")
'More Stuff
Private Sub addin_OnLinearContextMenu(SelectedEntities As ObjectsEnumerator, SelectionDevice As SelectionDeviceEnum, LinearMenu As CommandControls, AdditionalInfo As NameValueMap)
LinearMenu.AddButton(OriginConstrainCmd)
LinearMenu.AddButton(OriginConstrainCmdNX)
LinearMenu.AddButton(OriginConstrainCmdNY)
LinearMenu.AddButton(OriginConstrainCmdNZ)
End Sub
Commands themselves work fine, but on the Linear Menu object trying to use the other methods (AddButtonPopup, AddPopup, AddComboBox, AddSplitButton) all fail with a 'not implemented' error
Message 4 of 10
bradeneuropeArthur
'More stuff
'More Stuff
Dim a As ObjectCollection
a = ThisApplication.TransientObjects.CreateObjectCollection
a.Add(OriginConstrainCmd)
a.Add(OriginConstrainCmdNX)
a.Add(OriginConstrainCmdNY)
a.Add(OriginConstrainCmdNZ)
LinearMenu.AddSplitButton(OriginConstrainCmd,a, True, True, "BEFORE WHAT", True)
'''''''''else LinearMenu.AddSplitButton(OriginConstrainCmd,a, True, True,) End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
spencer
No dice unfortunately, still throwing exceptions on right-click.
System.NotImplementedException: 'Not implemented (Exception from HRESULT: 0x80004001 (E_NOTIMPL))'
Message 6 of 10
bradeneuropeArthur
also if you declare the buttondef as object
like dim OriginConstrainCmd as object
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 10
spencer
Neither declaring nor direct casting as an object seemed to make any difference
Message 8 of 10
etaCAD
A few years ago I tried as well to add grouped commands to the context menu and did many tests but there was no solution. This was not supported by the API.
Unfortunately, I think nothing changed so far.
Andreas
etaCAD
Message 9 of 10
bradeneuropeArthur
Hi @etaCAD ,
I remember that too.
For the Context menu this is not supported.
For the Ribbon and the menu's it is possible.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
spencer
Figured that might be the case. At least I know for sure and stop trying to find a way to make it work
