GoExcel.Open Already Open Excel Document
Ill keep this short and sweet. The short version is I'm trying to open an Excel Sheet (Ill call it ExcelData for now) and read in inputs and compare them to values in iProperties in Inventor. That all works and is great, the only issue I have is when more than one person tries to access ExcelData at once.
Using GoExcel.Open creates an issue when two people try to access ExcelData at the same time, it throws the prompt that ExcelData is locked for editing, and then shuts down the macro. Is there an alternative to this, or some way to amend this and have it open in like a read only mode or something of the sorts?
bradeneuropeArthur
could you give me a filename of the excel file that is to be opened?
imports System.io
Dim a As New System.IO.FileInfo("F:\Excel\filename.xls")
If a.IsReadOnly = False Then
	GoExcel.Open("F:\Excel\filename.xls", "Sheet1")
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
