Getting Virtual Components to be counted/included in an EXCEL BOM
Hi all.
I'm after some help in geting virtual Components to be included in an Excel output of an assy BOM. I have an existing macro (see code below) that exports the StockNumber, partNumber,Description and an occurrence count of each item to an Excel spreadshet. It all works fine except for Virtual Componenst which are not included. It seems that because no file is created that the VC item can't be included in the Excel doc. Can anybody shed some light on getting VC items included in the output?
Sub Assy2Excel()
Dim oAssDoc As AssemblyDocument
Set oAssDoc = ThisApplication.ActiveDocument
Dim SIPropSet As PropertySet
Set SIPropSet = oAssDoc.PropertySets.Item("Summary Information")
Dim rev As String
rev = SIPropSet.ItemByPropId(kRevisionSummaryInformation).Value
If oAssDoc.DocumentType <> kAssemblyDocumentObject Then
MsgBox "The Active document must be an 'Assembly'.", vbExclamation
Exit Sub
If MsgBox("The generated list is for the use of the Purchasing Department. It counts all of the BOUGHT & MADE parts in the assembly. Some manual editing will be required to 'clean up' the list. Do you want to continue?", vbYesNo + vbQuestion) = vbNo Then
Exit Sub
Dim oDocs As DocumentsEnumerator
Set oDocs = oAssDoc.AllReferencedDocuments
Dim oDoc As Document
Dim row As Integer
Dim excel_app As Excel.Application
app2check = "Excel.Application"
If IsApplicationRunning(app2check) = True Then
Set excel_app = Excel.Application
Else
Set excel_app = CreateObject("Excel.Application")
excel_app.Visible = True
excel_app.Workbooks.Add
With excel_app
.Columns("A:A").ColumnWidth = 13
.Range("A1").Select
Selection.Font.Bold = True
With Selection.Font
.Name = "Calibri"
.Size = 14
End With
.ActiveCell.FormulaR1C1 = "ASSEMBLY PARTS LIST-INCLUDES BOUGHT & MADE PARTS (Part QTY shown is for 1 of the Assembly No. shown below)"
'.Columns("A:A").ColumnWidth = 13
.Range("A2").Select
With Selection.Font
.Color = -6279056
.TintAndShade = 0
End With
.ActiveCell.FormulaR1C1 = "If the Assembly No. below does not end in -00000 then the QTY's shown may be wrong as this list has been generated from a sub-assembly!"
.Range("A3").Select
With Selection.Font
.Color = -16776961
.TintAndShade = 0
End With
.ActiveCell.FormulaR1C1 = "This list shows BOUGHT and MADE items but excludes quantities for Sheet Metal and Plasma parts (i.e. sheet and plate). CHECK THIS LIST AGAINST DRAWINGS BEFORE ORDERING PARTS/MATERIALS!"
.Range("A5").Select
.ActiveCell.FormulaR1C1 = "ASSEMBLY No. - " & Left(oAssDoc.DisplayName, Len(oAssDoc.DisplayName) - 4)
.Range("H4").Select
With Selection
.HorizontalAlignment = xlRight
End With
.ActiveCell.FormulaR1C1 = "REVISION - " & rev
.Range("A6").Select
.ActiveCell.FormulaR1C1 = "Stock Code"
.Columns("B:B").ColumnWidth = 13
.Range("B6").Select
.ActiveCell.FormulaR1C1 = "Part Code"
.Columns("C:C").ColumnWidth = 6
.Range("C6").Select
.ActiveCell.FormulaR1C1 = "Qty"
.Columns("D:D").ColumnWidth = 105
.Range("D6").Select
.ActiveCell.FormulaR1C1 = "Description"
.Columns("E:E").ColumnWidth = 15
.Range("E6").Select
.ActiveCell.FormulaR1C1 = "Supplier"
.Columns("F:F").ColumnWidth = 15
.Range("F6").Select
.ActiveCell.FormulaR1C1 = "P.O. Number"
.Columns("G:G").ColumnWidth = 15
.Range("G6").Select
.ActiveCell.FormulaR1C1 = "Date Ordered"
.Columns("H:H").ColumnWidth = 10
.Range("H6").Select
.ActiveCell.FormulaR1C1 = "Initials"
.Columns("H:H").ColumnWidth = 15
.Range("H1").Select
.ActiveCell.FormulaR1C1 = Date
.Range("H2").Select
.ActiveCell.FormulaR1C1 = Time
row = 6
For Each oDoc In oDocs
Dim oOccs As ComponentOccurrencesEnumerator
Set oOccs = oAssDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc)
Dim oPropSets As PropertySets
Set oPropSets = oDoc.PropertySets
Dim oProp1 As Property
Set oProp1 = oPropSets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kStockNumberDesignTrackingProperties)
oStockNumber = oProp1.Value
Dim oProp2 As Property
Set oProp2 = oPropSets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kPartNumberDesignTrackingProperties)
oPartNumber = oProp2.Value
Dim oProp3 As Property
Set oProp3 = oPropSets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kDescriptionDesignTrackingProperties)
oDescription = oProp3.Value
If oOccs.Count <> 0 Then
row = row + 1
With excel_app
.Range("A" & Format$(row)).Select
.ActiveCell.FormulaR1C1 = oStockNumber
.Range("B" & Format$(row)).Select
.ActiveCell.FormulaR1C1 = oPartNumber
.Range("C" & Format$(row)).Select
.ActiveCell.FormulaR1C1 = oOccs.Count
.Range("D" & Format$(row)).Select
.ActiveCell.FormulaR1C1 = oDescription
End With
Next
