Getting error for ImportedComponents.CreateDataExchangeDefinition
sneha.sadaphal
sneha.sadaphal
Hi
I am trying to import the online data in part environment in inventor 2024
but getting the error for
ImportedComponentDefinition oImportCompDef = oPartCompDef.ReferenceComponents.ImportedComponents.CreateDataExchangeDefinition(exchangeFileUrn, options);
 this api
Please help me out this if I am doing anything wrong.
here is the code for this issue
PartDocument pDoc = _document as PartDocument;
PartComponentDefinition oPartCompDef = pDoc.ComponentDefinition;
if (pDoc != null)
//Add new Occurance
var options = InventorApp.TransientObjects.CreateNameValueMap();
if (exchangeItem != null)
options.Add("Exchange", exchangeItem.FileURN);
oPartCompDef.ReferenceComponents.ImportedComponents.Add(oImportCompDef);
txn.End();
jadranko
Hello @sneha.sadaphal ,
CreateDataExchangeDefinition ignores the second argument.
You can omit creating the options object and passing it as an argument and replace your lines 1-14 with the following code:
if (pDoc != null)
    ImportedComponentDefinition oImportCompDef = oPartCompDef.ReferenceComponents.ImportedComponents.CreateDataExchangeDefinition(exchangeFileUrn);
Best regards,
Jadranko
sneha.sadaphal
Hi @jadranko I have tried the same as you suggested but getting same error as earlier.
jadranko
Please check two more things...
First, check that exchangeFileUrn actually is an urn of a Data Exchange container in Docs.
It should be a string looking something like this:
"urn:adsk.wipprod:dm.lineage:wfjaO3PZSwC2gWg2A1AvbQ"
Update: I've just seen in the article that it has to be prefixed like this:
"https://developer.api.autodesk.com/exchange/v1/exchanges?filters=attribute.exchangeFileUrn==urn:adsk.wipprod:dm.lineage:wfjaO3PZSwC2gWg2A1AvbQ"
Secondly, have you tried running it in an Assembly document instead of the Part document?
Here is an article describing how to do it:
Mod the machine: Import Data Exchange Model
Best regards,
Jadranko
sneha.sadaphal
Hi @jadranko
For first check, the exchange urn I am getting below as string
https://developer.api.autodesk.com/exchange/v1/exchanges?filters=attribute.exchangeFileUrn==urn:adsk...
For second check, yes, it is working as expected in assembly environment.
jadranko
Hi @sneha.sadaphal and @Yogesh_Shinde ,
I might be wrong, but it seems that it is not possible to reference Data Exchange from a part document.
It is mentioned in several places that Data Exchange could be used to bring the Data Exchange reference into assembly, although I could not find any specific statement that it cannot be used within a part.
By using latest beta of Data Exchange Connector for Inventor 2023 (not the built-in one), I managed to reference Data Exchange from a part document, but it seems that it actually created a STEP model on the fly and imported it instead.
If that is the case it probably should be mentioned in the API documentation.
More descriptive exception would be helpful as well.
Best regards,
Jadranko
