how to turn of error notification - Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
srinivasanyl
srinivasanyl
Steps to reproduce
Im using one ilogic rule for extend length of the flat patten objects.
i added the rule in event trigger - part - before save.
some of the parts does not the flat pattern type parts like rods, angles etc..
eventhough the rule runs for that type of parts and its not an issue. but error notification is coming. how to avoid/or turn off this error message?
ilogic Code was
extents_length = SheetMetal.FlatExtentsLength
extents_width = SheetMetal.FlatExtentsWidth
iProperties.Value("Custom", "LENGTH") = extents_length
iProperties.Value("Custom", "WIDTH") = extents_width
iProperties.Value("Custom", "THK") = Parameter("Thickness")
Expected results
A modified Code
Actual results
image attached
URL where issue occurs
Browser
Microsoft Edge
OS
Windows
FINET_Laurent
Hi @srinivasanyl,
You could simply put this code in a try /catch statement like so :
Try
Catch
End Try
Here is some info : Visual Basic Try Catch Statement - Tutlane
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Michael.Navara
Another option without exception handling is to check the DocumentSubType and exit rule when the document is not sheet metal part
Dim isShetmetal As Boolean = ThisDoc.Document.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
If Not isShetmetal Then Return
Michael.Navara
Both of this methods works, but if you are interested about performance, my method is approximately
  • 8-times faster for another rule call
  • 400-times faster when you stay in the same rule
You can check the benchmark in attached document.
Sub main
	Dim start0 = DateTime.Now
	For i = 0 To 1000
		DocumentSubTypeCheck()
	Next
	Dim duration0 = DateTime.Now - start0
	Dim start1 = DateTime.Now
	For i = 0 To 1000
		TryCatchException()
	Next
	Dim duration1 = DateTime.Now - start1
	Logger.Debug("{0:N0} - DocumentSubTypeCheck", duration0.TotalMilliseconds)
	Logger.Debug("{0:N0} - TryCatchException", duration1.TotalMilliseconds)
End Sub
Sub DocumentSubTypeCheck()
End Sub
Sub TryCatchException()
	Try
	Catch
	End Try
End Sub
FINET_Laurent
