Get vector values from view cube Inventor API
karolis.s
karolis.s
Hello.
I need to get / create a UCS based on default TOP value of the view cube. (End Task is to store this matrix to SQL DB and read it from Fusion)
So it means
zVector: normal of kTopViewOrientation
xVector: normal of kRightViewOrientation
yVector: normal of kBackViewOrientation
@kandennti
I have tried to change camera view, apply it, than read UpVector properties, but I do not get expected values..
I have also tried to simply use  camera.ModelToViewTransformation matrix, but again I do not get expected values mentioned above..
Any ideas? Thank you.
Andrii_Humeniuk
Hi @karolis.s . I wrote iLogic code that creates a UserCoordinateSystem in the PartDocument according to the ViewBox coordinates. I hope this example helps you.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oUCSs As UserCoordinateSystems = oDoc.ComponentDefinition.UserCoordinateSystems
Dim oUCS As UserCoordinateSystem
Dim oCamera As Camera = oDoc.Views.Item(1).Camera
Dim oUCSDef As UserCoordinateSystemDefinition
Try
	oUCS = oUCSs("new UCS")
	oUCS.Transformation = oCamera.ModelToViewTransformation
Catch
	oUCSDef = oUCSs.CreateDefinition()
	oUCSDef.Transformation = oCamera.ModelToViewTransformation
	oUCS = oUCSs.Add(oUCSDef)
	oUCS.Name = "new UCS"
End Try
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Michael.Navara
Try this code
Dim cam As Camera = ThisApplication.ActiveView.Camera
cam.ViewOrientationType = ViewOrientationTypeEnum.kRightViewOrientation
Dim x As Vector = cam.Target.VectorTo(cam.Eye)
cam.ViewOrientationType = ViewOrientationTypeEnum.kBackViewOrientation
Dim y As Vector = cam.Target.VectorTo(cam.Eye)
cam.ViewOrientationType = ViewOrientationTypeEnum.kTopViewOrientation
Dim z As Vector = cam.Target.VectorTo(cam.Eye)
Logger.Debug("x = [{0:N2}, {1:N2}, {2:N2}]", x.X, x.Y, x.Z)
Logger.Debug("y = [{0:N2}, {1:N2}, {2:N2}]", y.X, y.Y, y.Z)
Logger.Debug("z = [{0:N2}, {1:N2}, {2:N2}]", z.X, z.Y, z.Z)
karolis.s
I have tried this method, it was the closest I could to the end result.. But Z axis is flipped on the part where origin is similar to wanted end result..
And if origin Z axis is looking to other direction than top I get totally wrong output..
karolis.s
Thank you for your time.
This way is also not giving me end result
Michael.Navara
I depends on how you create the UCS
In my opinion it works as expected
Dim part As PartDocument = ThisDoc.Document
Dim cam As Camera = part.Views(1).Camera
'Create UCS
Dim origin As Point = ThisApplication.TransientGeometry.CreatePoint()
Dim mtx As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
mtx.SetCoordinateSystem(origin, x, y, z)
Dim ucsDef As UserCoordinateSystemDefinition = part.ComponentDefinition.UserCoordinateSystems.CreateDefinition()
ucsDef.Transformation = mtx
part.ComponentDefinition.UserCoordinateSystems.Add(ucsDef)
