get value of balloons and copy to iproperties of each in parts list
Message 1 of 10
Hi Guys,
Anyone have any rules that I can run in drawing to -
Get the value of balloon for every item (assembly or part) in the parts list and copy it to a iproperty in the model files.
Replies (9)
Message 2 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to copy balloon no. to custom iProperties of model document.
Sub Main()
	Dim doc = ThisDoc.Document
	If doc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		Dim oSheet As Sheet
		oSheet = ActiveSheet.Sheet
		Dim oBalloon As Inventor.Balloon
		For Each oBalloon In oSheet.Balloons
			Dim oReferDoc As Document
			oReferDoc = oBalloon.BalloonValueSets.Item(1).ReferencedFiles.Item(1).ReferencedDocument
			Update_Balloon_Number(oBalloon.BalloonValueSets.Item(1).ItemNumber, oReferDoc)
		Next
	Else
		MessageBox.Show("Current docuement is not Drawing", "Document")
	End If
End Sub
Sub Update_Balloon_Number(ByVal ItemNumber As String, ByVal oDoc As Document)
	Try
		oDoc.PropertySets.Item("Inventor User Defined Properties").Item("Balloon_Number").Value = ItemNumber
	Catch
		'catch error when iproperty doesn't exist and create it
		oDoc.PropertySets.Item("Inventor User Defined Properties").Add("", "Balloon_Number")
		'then set the property
	End Try
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 10
This rule runs but doesn't seem to work. After I run it when I check the parts custom iprop the "Balloon_Number" property hasn't been created.
Sandy
Message 4 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Can you please sample drawing file with assembly to test? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 10
No I cant send the files unfortunately due to confidentiality.
The reason I am doing this is because I ultimately want to add a prefix to my item numbers in the parts list.
In the BOM you can add expressions to every column (i.e. to display 2 values) except the 'Item' column. This cannot be edited.  I was trying to duplicate all the items numbers to a custom property to I can then add to this to display 2 values.
Perhaps this wont work.....do you know of any way to add a prefix to balloon numbers?
Sandy
Message 6 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to add prefix to balloon number.
Sub Main()
		Dim oSheet As Sheet
			oBalloon.BalloonValueSets.Item(1).value = "00-" + oBalloon.BalloonValueSets.Item(1).ItemNumber
		Next
	Else
	End If
End Sub
Please feel free to contact if there is any queries.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 10
Yes this works although if an item is ballooned twice it will add the prefix twice...…..can it be changed to item or part rather then balloon?
Also, would like to add a '-' between prefix and balloon number.  How can I do this? I have edited the code below so it prefix the property 'Title'
See below.
Sandy
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 6452 StartFragment: 314 EndFragment: 6420 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Sub Main()
        Dim oSheet As Sheet
            oBalloon.BalloonValueSets.Item(1).Value = iProperties.Value("Summary", "Title") + oBalloon.BalloonValueSets.Item(1).ItemNumber
        Next
    Else
    End If
Message 8 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try this iLogic code now.
Sub Main()
        Dim oSheet As Sheet
        Dim al As New ArrayList()
			If Not (al.Contains(oBalloon.BalloonValueSets.Item(1).ItemNumber )) Then
			    al.Add(oBalloon.BalloonValueSets.Item(1).ItemNumber )
			End If
        Next
		Dim i As Integer = 0
			If oBalloon.BalloonValueSets.Item(1).ItemNumber = al(i) Then
				oBalloon.BalloonValueSets.Item(1).Value = iProperties.Value("Summary", "Title") + " - "+ oBalloon.BalloonValueSets.Item(1).Value
				i = i + 1
			End If
		Next
    Else
    End If
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 10
Cheers.
Would there be any code to reset item number to static value? (I.e. remove the prefix)
Sandy
Message 10 of 10
Found this:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 5878 StartFragment: 314 EndFragment: 5846 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
Dim oPartsList As Partslist
oPartsList = oSheet.PartsLists(1)
Dim oRow As PartsListRow
Dim oColumn As PartsListColumn
For Each oRow In oPartsList.PartsListRows
For Each oColumn In oPartsList.PartsListColumns
    oRow.Item(oColumn).Static = False
    Next oColumn
Next oRow
iLogicVb.RunRule("Renumber Items")
