ilogic to get balloon no. of every (asembly/part) in parts list & copy in iprop.
Hi Guys,
Anyone have any rules that I can run in drawing to -
Get the value of balloon for every item (assembly or part) in the parts list and copy it to a iproperty in the model files.
Sandy
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below iLogic code to copy balloon no. to custom iProperties of model document.
Sub Main()
	Dim doc = ThisDoc.Document
	If doc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
		Dim oSheet As Sheet
		oSheet = ActiveSheet.Sheet
		Dim oBalloon As Inventor.Balloon
		For Each oBalloon In oSheet.Balloons
			Dim oReferDoc As Document
			oReferDoc = oBalloon.BalloonValueSets.Item(1).ReferencedFiles.Item(1).ReferencedDocument
			Update_Balloon_Number(oBalloon.BalloonValueSets.Item(1).ItemNumber, oReferDoc)
		Next
	Else
		MessageBox.Show("Current docuement is not Drawing", "Document")
End Sub
Sub Update_Balloon_Number(ByVal ItemNumber As String, ByVal oDoc As Document)
	Try
		oDoc.PropertySets.Item("Inventor User Defined Properties").Item("Balloon_Number").Value = ItemNumber
	Catch
		'catch error when iproperty doesn't exist and create it
		oDoc.PropertySets.Item("Inventor User Defined Properties").Add("", "Balloon_Number")
		'then set the property
	End Try
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
