Get the number of holes on a part (use Hole command "From sketch")
ngocson8335
ngocson8335
Dear Experts,
I'm Son, I'm a User Inventor. I'm coding a code to get the number of holes, but I can't get it.
I'm using Microsoft Visual Studio to coding.
Please help me to suggest the ways or example codes.
Thank you so much.
Ngoc Son
Autodesk User
bradeneuropeArthur
Public Sub Getthenumberofholesonapart()
Dim a As Application
Set a = ThisApplication
Dim b As PartDocument
Set b = a.ActiveDocument
Dim fe As HoleFeature
MsgBox b.ComponentDefinition.Features.HoleFeatures.Count
End Sub
MsgBox b.ComponentDefinition.Features.HoleFeatures.Item(1).HoleCenterPoints.Count
End Sub
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
ngocson8335
That great!!! Thank you for your help!!!
Ngoc Son
Autodesk User
bradeneuropeArthur
Your thanks are appreciated...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
