Get the Browser Folder containing a component occurrence or occurrence pattern?
amitabhVA4SD
amitabhVA4SD
Is there any direct API that fetches the Browser Folder containing a component occurrence or an occurrence pattern?
We can get the Browser Node from a component occurrence using the BrowserPane.GetBrowserNodeFromObject but I couldn't find an API to get to the containing folder from the browser node.
I also found out that the GetBrowserNodeFromObject may not be a good solution in the case of component patterns
https://adndevblog.typepad.com/manufacturing/2013/04/get-browsernode-of-an-occurrence.html
I need to let the user select a component occurrence and display the containing folder Name. What is the most optimized way to handle this using Inventor API?
Inventor API Team and Experts please help
@MjDeck @JelteDeJong @YuhanZhang
Amitabh Mukherjee
A.Acheson
Hopefully I am correct here, you will need to loop through the browser folders and look for the object to match that you have selected then retrieve the folder name when found. I don’t believe the occurrence objects have any knowledge of the container/folder they are inside.
https://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-A2D7CBA0-28F5-400E-94E3-FB51D8AD9C71
This post deals with patterns inside folders but with the folder name already determined.
https://adndevblog.typepad.com/manufacturing/2015/05/suppress-folder-in-assembly.html
Regards
Alan
amitabhVA4SD
Thank you, @A.Acheson!
That example explains clearly the Inventor API Object Model hierarchy related to the BrowserPane and BrowserNode
BrowserPane > TopNode > BrowserFolders > BrowserFolder > BrowserNode > BrowserNodes  > NativeObject
Let us wait to see if the Inventor API Internal team has a better approach to the problem.
Michael.Navara
This is a small sample how to extract folder name from occurrence and display it in PromptMessage during pick
Sub Main
	Dim activeDoc As Document = ThisDoc.Document
	Dim browser As BrowserPane = activeDoc.BrowserPanes.ActivePane
	Dim pick As Object
	Dim prompt = "Select pattern element"
	Do
		StartSelection :
		pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, prompt)
		Try
			Dim occ As ComponentOccurrence = pick
			Dim node = browser.GetBrowserNodeFromObject(occ)
			Dim parentNode As BrowserNode = node.Parent
			Do While parentNode IsNot Nothing
				If parentNode.NativeObject.Type = ObjectTypeEnum.kBrowserFolderObject Then
					prompt = parentNode.BrowserNodeDefinition.Label
					GoTo StartSelection
				End If
				parentNode = parentNode.Parent
			Loop
		Catch
			' Ignore
		End Try
	Loop While pick IsNot Nothing
End Sub
