Group Views based on Stock number
floccipier
Message 1 of 14
floccipier
Hi all,
I am trying to arrange views so that similar stock numbers are in one group, while I can read the stock, add that to list and sort that I am bit clueless to use this information ot actually move and group views, any help regarding this would be highly appreciated.
best regards,
Sam
Replies (13)
Message 2 of 14
A.Acheson
Hi Sam,
Are you talking about moving drawing views here or something else? Can you share the rule you are using and some images of your desired workflow.
Regards
Alan
Message 3 of 14
floccipier
@A.Acheson wrote:
Hi Sam,
Hi Acheson,
Thanks for your reply, and yes I am talking about drawing views.
so below is the code which reads all the stock number of part used in view and adds it to lits and later part of the code displays sorted list.
Dim oApp = ThisApplication
Dim oDrawDoc As DrawingDocument
oDrawDoc = oApp.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
Dim oList As New List(Of String)
Dim oSN As String
For Each oView As DrawingView In oSheet.DrawingViews
oSN = (oView.ReferencedDocumentDescriptor.ReferencedDocument.PropertySets.Item _
("Design Tracking Properties").Item("Stock Number").Value)
oList.Add(oSN)
oList.Sort
Next
For Each str As String In oList
	 MessageBox.Show(Str)
Next
What I am trying to achieve is to arrange same stock number (part) views on drawings in one group (in one row may be) e.g.  all views with parts having "10 mm Plate" should be one group, "16 mm Plate" another group and son on.
Let me know please if i need to provide more info.
Message 4 of 14
floccipier
@JelteDeJong sorry to tag you but if you have bit of time to have a look at this please.
Message 5 of 14
WCrihfield
Just to clarify the details of this task a bit more.  How many views are we talking about here on one sheet?  How do you want them grouped (each group is 1 vertical line of views ; each group is 1 horizontal line of views ; each group is rectangular with x number of columns and x number of rows ; other ; don't care)?  On the subject of knowing how to know which stock numbers to group together, do you mean that there may be multiple view which are using the same stock number, then only group views of that same stock number together, or are there stock numbers that are somehow similar to each other that you want grouped together?  If they are just similar, then how do we know which ones to group together?  How much space do you want between these views & groups of views?  What sheet size and orientation are you using?  Is there a Border & TitleBlock that we need to avoid when placing these views on the sheet?  Where is the TitleBlock on the sheet, and does it span the full width of the sheet, or just partial?
When doing it manually, with all of it in front of us is one thing, but trying to do this completely on a code screen, having never seen the drawing or the views to reference is quite another.
Some screen captured images of examples might help here, because as they say, "A picture is worth a thousand words."
Wesley Crihfield
(Not an Autodesk Employee)
Message 6 of 14
floccipier
@WCrihfield Thanks for the reply.
@WCrihfield wrote:
Just to clarify the details of this task a bit more.  How many views are we talking about here on one sheet? sometimes more than hundred. How do you want them grouped (each group is 1 vertical line of views ; each group is 1 horizontal line of views ; each group is rectangular with x number of columns and x number of rows ; other ; don't care)?  Each group in 1 hozrizontal Line. On the subject of knowing how to know which stock numbers to group together, do you mean that there may be multiple view which are using the same stock number, then only group views of that same stock number together, or are there stock numbers that are somehow similar to each other that you want grouped together? I have section (e.g. 100x50PFC) or Plate thickness (e.g. 6mm No Fold) description in stock number. So the code should group views of same stock number.  If they are just similar, then how do we know which ones to group together?  they have either same stock number or not, there is nothing as similar. How much space do you want between these views & groups of views?  What sheet size and orientation are you using?  Is there a Border & TitleBlock that we need to avoid when placing these views on the sheet?  Where is the TitleBlock on the sheet, and does it span the full width of the sheet, or just partial? We don't want veiws to overlap each other (5mm gap between two adjacent views). Considering some items are really small, In no case the gap between two views should be less than 10mm.  There are is no border and block restriction, views can be arranged and grouped anywhere needed. to make it simple lets assume that there is no title block.
code can group it whereever needed (even outside of sheet if that's easy) and then designer would arrange the views however like or even copy and place them to additional sheets.
I can't post anything there, but if you have an email I can send you the a screen grab.
Best regards,
Flo
Message 7 of 14
JelteDeJong
Is this what you are looking for?
Sub Main()
    Dim doc As DrawingDocument = ThisDoc.Document
    Dim sheet As Sheet = doc.ActiveSheet
    Dim viewDic As Dictionary(Of DrawingView, String) = New Dictionary(Of DrawingView, String)()
    For Each view As DrawingView In sheet.DrawingViews
        viewDic.Add(View, GetStockNumber(View))
    Next
    Dim viewDicOrderd = viewDic.OrderBy(Function(item) item.Value)
    Dim curentX As Double = 0
    Dim curentY As Double = 0
    Dim previousStockNumber As String = viewDicOrderd.First.Value
    Dim nextY As Double = 0
    For Each item In viewDicOrderd
        Dim view = item.Key
        Dim stockNumber = item.Value
        If (view.Parent IsNot sheet) Then
            view.CopyTo(sheet)
        If (stockNumber <> previousStockNumber) Then
            curentX = 0
            curentY = curentY + nextY + 0.5
        MoveView(item.Key, curentX, curentY)
        curentX = curentX + view.Width + 0.5
        nextY = Math.Max(nextY, view.Height)
        previousStockNumber = stockNumber
    Next
End Sub
Public Sub MoveView(view As DrawingView, X As Double, Y As Double)
    Dim oTg As TransientGeometry = ThisApplication.TransientGeometry
    X = X + view.Width / 2
    Y = Y + view.Height / 2
    Dim pos As Point2d = oTg.CreatePoint2d(X, Y)
    view.Position = pos
End Sub
Public Function GetStockNumber(view As DrawingView)
    Try
        Dim doc As Document = view.ReferencedDocumentDescriptor.ReferencedDocument
        Dim propSet As PropertySet = doc.PropertySets.Item("Design Tracking Properties")
        Dim prop As [Property] = propSet.Item("Stock Number")
        Return prop.Value
    Catch ex As Exception
        Return ""
    End Try
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
Message 8 of 14
floccipier
Thank you so much, exactly what I needed.
Every time you provide solution it not only solves my problem it always teaches me more ways to doing things. Please accept gift of coffee which is not substitute of your time and effort, its merely way of saying thanks to you.
good night.
Message 9 of 14
JelteDeJong
Thank you for the coffee and have a good night!
Jelte de Jong
Message 10 of 14
floccipier
Hi @JelteDeJong
your solution is delivering exactly what I requested for in OP but I have realised now that for each "Stock No" there are so many parts. Is it possible that it places views of every stock No on to a new sheet (renaming sheet name to Stock No). Sorry I should have thought about it in the beginning.
Message 11 of 14
floccipier
@JelteDeJong I tried updating to put group of same stock number views on separate sheet - it creates the sheets ( I counted it creates as many as types of stock numbers and adds just one view on each sheet) but doesn't not successfully moves all the views. Can you please help me modify this, would be huge favour. Thank you.
@floccipier wrote:
Hi @JelteDeJong
Message 12 of 14
JelteDeJong
you can try this:
Sub Main()
    Next
    Dim newSheet As sheet = doc.Sheets.Add()
    newSheet.Name = previousStockNumber
        Dim view = item.Key
            curentX = 0
            curentY = 0 ' curentY + nextY + 0.5
            newSheet = doc.Sheets.Add()
            newSheet.Name = stockNumber
        view = view.CopyTo(newSheet)
        MoveView(view, curentX, curentY)
    Next
    ' uncomment this next line if you want to delete the first sheet.
    ' sheet.Delete()
End Sub
    view.Position = pos
End Sub
    Try
        Return prop.Value
        Return ""
    End Try
End Function
Jelte de Jong
Message 13 of 14
floccipier
Thank you so much.
Message 14 of 14
floccipier
i have sent you one email, commeting this to make sure that it doesn't go unattended or to spam.
