Just to clarify the details of this task a bit more. How many views are we talking about here on one sheet? How do you want them grouped (each group is 1 vertical line of views ; each group is 1 horizontal line of views ; each group is rectangular with x number of columns and x number of rows ; other ; don't care)? On the subject of knowing how to know which stock numbers to group together, do you mean that there may be multiple view which are using the same stock number, then only group views of that same stock number together, or are there stock numbers that are somehow similar to each other that you want grouped together? If they are just similar, then how do we know which ones to group together? How much space do you want between these views & groups of views? What sheet size and orientation are you using? Is there a Border & TitleBlock that we need to avoid when placing these views on the sheet? Where is the TitleBlock on the sheet, and does it span the full width of the sheet, or just partial?
When doing it manually, with all of it in front of us is one thing, but trying to do this completely on a code screen, having never seen the drawing or the views to reference is quite another.
Some screen captured images of examples might help here, because as they say, "A picture is worth a thousand words."
Wesley Crihfield
(Not an Autodesk Employee)
