Get the axis of a cylinder part
dialunau
dialunau
Hello, I've been trying to get the axis of a cylinder inside an insert constraint. The problem is that ilogic doesn't recognize the axis of the cylinder as a work feature, so I can't get access to it with the method I'm trying to use.
Does anyone know how to solve this?
My code looks like this:
Dim oAssy As AssemblyDocument = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition
oDef = oAssy.ComponentDefinition
Dim oCons As AssemblyConstraint
oCons = oDef.Constraints.Item("Insert:1")
Dim oEnt As Object
oEnt = oCons.EntityOne
Dim oAxis As WorkAxis
If (TypeOf oEnt Is WorkAxis) = True Then
	oAxis = oEnt
	MsgBox("Entity one is the cylinder axis")
End If
J-Camper
I think InsertConstraint Entities are Circular Edges, so you could look through it's connected Faces to find a Face with Cylinder Geometry to get a UnitVector, but the Entity won't be a WorkAxisObject.  Another way to get the UnitVector is to look at the Geometry instead of the Entity.  This gives you Assembly oriented center point and normal UnitVector for the input Entity.
I have a quick example below which creates a Fixed Workaxis [Only method currently supported in Assembly Environment] based on input 1 for a given InsertConstraint:
Dim AsmDef As AssemblyComponentDefinition = TryCast(ThisApplication.ActiveDocument.ComponentDefinition, AssemblyComponentDefinition)
If IsNothing(AsmDef) Then Logger.Trace("Not run in Assembly Environment") : Exit Sub
Dim i As Integer = 2
Dim InCon As InsertConstraint = TryCast(AsmDef.Constraints.Item(i), InsertConstraint)
If IsNothing(InCon) Then Logger.Trace("Constraint #" & i & " is not an Insert Constraint") : Exit Sub
'Logger.Trace(CType(InCon.EntityOne.Type, ObjectTypeEnum).ToString)
Dim circle1 As Circle = TryCast(InCon.GeometryOne, Circle)
If IsNothing(circle1) Then Logger.Trace("Geometry is not a Circle") : Exit Sub
Dim circle1Center As Point = circle1.Center
Dim circle1Normal As UnitVector = circle1.Normal
Dim Occurrence1Axis As WorkAxis = AsmDef.WorkAxes.AddFixed(circle1Center, circle1Normal, False)
I'm not sure what you want to do with this information, but if you have any questions or would like any more assistance, let me know.
gcoombridge
JCamper beat me to it but here is your code reworked to confirm entityone is an edge:
Dim oEnt As Object
Dim oEdge As Edge
If (TypeOf oEnt Is Edge) = True Then
	oEdge = oEnt
Else
	msgbox("Nothing")
End If
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
