Hole Table Label - Relabelling as new
gopinathmY575P
gopinathmY575P
Hello Community,
i have attached two images(ht1,ht2). In image ht1, there is a hole table before updating/modifying my changes to the part,with labels A1 to B4 tags. After making changes to the part, once again when i try place the Hole table, it is once agin relabelling with some other new tags as in image ht2.
i need a snippet, which will update the existing hole table itself. Do not relabell and create a new one.
Thanks in advance
theo.bot
There is an option ( preserve tagging) in the hole table style that preserves the hole tags. so with this option it keep the same tagging for the hole labels after changes. Disabled, it will update the entire table, like its a new table.
gopinathmY575P
Hello sir, thank you for the response.
what will happen ? when i add new hole feature in the model, that data will reflect in the existing hole table? if not reflecting, what to do,to reflect in the existing hole table.
Thanks in advance sir..
theo.bot
Hi @gopinathmY575P
As long as you use "Hole Table View" all holes will be updated automaticly.
gopinathmY575P
Thank you for your valuable support.
