Get part coordinates and orientation in an Inventor assembly
Hi all,
I need to get the position and orientation of each part in my assembly. As far as I know using the forum search I need the ComponentOccurrences.Transformation property.
The values represent the offset from the assembly coordinate system to every part coordinate system, right?
My problem is that the above mentioned property contains only x,y,z-values for the translation but no values (not even a property) for rotation. I read in another thread that there should be information on the orientation though.
I hope someone can help me. Thank you in advance,
Sebastian
MechMachineMan
Pretty sure there is another property of the matrix you can use. Or just accessing the cells 1x1. In the API help (file: *ad_mapi* in windows explorer) it gives a rundown of the matrices and such and how to access the various values.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
