Get name of feature, based on the used sketch - Ilogic
jaco011
jaco011
Hi all,
I am currently working on a Ilogic rule to find easily undefined sketches, to check a part. I have already the code as shown below. Which makes undefined sketches visible and shows the names of those sketches in a message box. But to find these sketches you still have to search trough your features. Anybody know how to get the name of the feature where a sketch is used in?
My goal is that the messagebox say "1 undefined sketch. Sketch 3 used in extrude 5"
Anyone with suggestions?
Thanks a lot
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim counter As Integer = 0
Dim oSketch As PlanarSketch
Dim ListSketch As New ArrayList
Dim oText As String
For Each oSketch In oDoc.ComponentDefinition.Sketches
	If oSketch.ConstraintStatus <> 51713  Then
		oSketch.Visible = True
		counter += 1
		Dim oSketchName As String = oSketch.Name
		ListSketch.Add(oSketch.Name)
	Else
		oSketch.Visible = False
	End If
Next
For i As Integer = 0 To ListSketch.Count - 1
	If i = 0 Then
		oText = ListSketch(i)
	Else
		oText = oText & vbLf & ListSketch(i)
	End If
Next
If counter = 0 Then
	MessageBox.Show("Good job, no undefined sketches!", "No undefined sketches",MessageBoxButtons.OK)
Else
	MessageBox.Show("There are " & counter & " undefined sketches." & vbLf & vbLf & "The following sketches are undefined" & vbLf & oText, counter &"Undefined sketches",MessageBoxButtons.OK)
End If
JhoelForshav
Hi @jaco011
Since a sketch can have multiple features depending on it, we'll have to find them all...
This is a small example that finds the part features depending on a sketch 🙂
Dim oSketch As PlanarSketch = ThisDoc.Document.ComponentDefinition.Sketches(1) 'Get a sketch
Dim oNames As String = "Features:"
For Each oObj In oSketch.Dependents
	If TypeOf (oObj) Is PartFeature Then oNames = oNames & vbCrLf & DirectCast(oObj, PartFeature).Name
Next
MsgBox(oNames)
jaco011
Thanks that worked!
My final code will be;
Dim ListFeature As New ArrayList
Dim oText As String
Next
               counter += 1
               oNames = ""
                               oNames = oNames & vbCrLf & "   > " & DirectCast(oObj, PartFeature).Name
                       End if
                       Next
               ListFeature.Add (oNames)
        End If
Next
        If i = 0 Then
               oText = ListSketch(i) & " used in " & ListFeature(i) & vbLf
        Else
               oText = oText & vbLf & ListSketch(i) & " used in " & ListFeature(i)
        End If
Next
If counter = 0 Then
        MessageBox.Show("Good job! No undefined sketches in this part", "No undefined sketches",MessageBoxButtons.OK)
Else
        MessageBox.Show("There are " & counter & " undefined sketches" & vbLf & vbLf & "It is about the following sketches" & vbLf & vbLf & oText, counter &" undefined sketches",MessageBoxButtons.OK)
End If
