Get list of all parts from assembly using apprentice server
danijel.radenkovic
danijel.radenkovic
I am working on my first addin and I need to get list of parts (their filenames) from an assembly which I chose using file open dialog.
Thanks in advance friends
Danijel.
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
Hi Daniel,
Here is the code you need
Sub test()
   Dim nModel As AssemblyDocument
   Set nModel = ThisApplication.ActiveDocument
   Dim nDocEnum As DocumentDescriptorsEnumerator
   Set nDocEnum = nModel.ReferencedDocumentDescriptors
   For Each Item In nDocEnum
     Debug.Print Item.FullDocumentName
   Next Item
End Sub
You need to open Immediate window (Ctrl+G) to see result.
Regards
Nedeljko.
danijel.radenkovic
Hello Nedeljko,
This should works when I put code into ilogic rule or inventor vba, but I need to manage with Inventor properties without opening Inventor, using apprentice server.
 I think I am close to the solution with this:
 For Each n As Inventor.ComponentOccurrence In apprenticeDoc.ComponentDefinition.Occurrences
      lablel.Text = apprenticeDoc.ComponentDefinition.Occurrences(Name).ToString
 Next
danijel.radenkovic
Finaly, I resolved with this code.
  For Each occ As Inventor.ComponentOccurrence In apprenticeDoc.ComponentDefinition.Occurrences
                If occ.DefinitionDocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
                ListBox1.Items.Add(occ.Name)
 Next
Thanks for your help Nedeljko
Best regards
Danijel
