Access Date
Access Date
Access Date
<->Can I create an iProperty to show an Access Date?
Hi, Alayars,
Yes, you can. How do you want to do that?
1. Manualy through Inventor inteface (iProperty window) or,
2. through VBA code, i.e. object tree.
1. Type Access Date in field Name on Custom tab in iProperties window
2. Choose Date from drop down list in field Type
3. Type in field Value date and check it in check box.
4. Click on Add and OK.
if you want to modify access date-click on your access date in table, enter new access date in field Value, click on Modify button, and OK.
If you want to use VBA code:
Sub test()
   Dim nModel As PartDocument
   Set nModel = ThisApplication.ActiveEditDocument
   Dim nPropSetCust As PropertySet
   Set nPropSetCust = nModel.PropertySets(4)
   Dim nAccessDate As Property
   Set nAccessDate = nPropSetCust.Add(#5/9/2014#, "Access date")
End Sub
Custom properties you can find in PropertySet>Item (4)
Date type between #
Best regards,
Nedeljko
