Get iProperties from part in drawing with iLogic and VBA
GeorgK
Advisor Advisor
Message 1 of 20
GeorgK
Hello together,
how could I synchronize my drawing with the referenced part?
I have a "User Defined Propertie" called  "RBMATNO" in the part and in the drawing.
Thank you very much
Georg
Replies (19)
Message 2 of 20
adam.nagy
Autodesk Support
Autodesk Support
Hi Georg,
You should be able to do something like this - e.g. in VBA:
Sub SynchronizeUserParam()
    Dim dwg As DrawingDocument
    Set dwg = ThisApplication.Documents(2)
    Dim part As PartDocument
    Set part = ThisApplication.Documents(1)
    Dim param As Variant
    param = dwg.Parameters("RBMATNO").Expression
    part.ComponentDefinition.Parameters("RBMATNO").Expression = param
End Sub
Cheers,
Adam Nagy
Autodesk Platform Services
Message 3 of 20
GeorgK
Thank you very much.
Message 4 of 20
adam.nagy
Autodesk Support
Autodesk Support
oops... not sure know why I thought you said Parameters - which my code was about.
This is how you synchronize an iProperty inside "User Defined Properties"
Sub SynchronizeiProperty()
    Set dwg = ThisApplication.Documents(1)
    Set part = ThisApplication.Documents(2)
    ' Accessing "User Defined Properties" set
    Dim dps As PropertySet
    Set dps = dwg.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
    Dim pps As PropertySet
    Set pps = part.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
    param = dps("MyProperty").Expression
    pps("MyProperty").Expression = param
End Sub
Adam Nagy
Message 5 of 20
Adam
Will this work in iLogic?
If not, can it be done in iLogic?
If so, how?
Will this work in Inv2015?
Message 6 of 20
adam.nagy
Autodesk Support
Autodesk Support
You just have to convert it to iLogic compatible code:
http://adndevblog.typepad.com/manufacturing/2015/11/convert-vba-to-net-ilogic.html
Cheers,
Adam Nagy
Message 7 of 20
Owner2229
Hi, you can use this:
oModelRef = ThisDrawing.Document.Sheets.Item(1).DrawingViews.Item(1).ReferencedFile
ModelFileName = oModelRef.FullFileName
oModelDoc = ThisApplication.Documents.Open(ModelFileName, 0)
iProperties.Value("Custom", "RBMATNO") = oModelDoc.PropertySets.Item("User Defined Properties").Item("RBMATNO").Value
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 8 of 20
ThomasSwanson
Or you could just have Inventor do this for you and not worry with ilogic and VBA.
Create the custom Iproperty on the drawing template.
Then got to Tools --> Document Settings--> Drawing Tab
At the bottom you will see Copy Model iproperty Settings click on that and put a check in the two check boxes.
Message 9 of 20
I have a multi-sheet drawing, but still need to access Part iProperties
Message 10 of 20
adam.nagy
Autodesk Support
Autodesk Support
As shown in one of the sample codes above, you can find out which document is referenced by a given view on a given sheet.
So you can just iterate through the sheets and the views on them and then access the iproperties of those doucments and then do with them whatever you need to.
Adam Nagy
Message 11 of 20
Hi I am trying to do something very similar, We have profile  drawings (sheets for laser cutting) on the 2nd last page (eg 15th sheet) of every drawing set. The page number of the sheet is manually written onto i-properties of each part.
Whenever there is an additional sub assembly added we end up manually changing the  iproperties by incrementing by the additional pages we added. ie if we added 2 pages of subassembly to the drawing sets the new profile page will be moved to sheet 17.
i am stuck where i need to pass the page number to part, i am not getting the right syntax , may be you might be able to help me here.TIA.
regerds
Mithun
Sub Sheet_NO_2_parts()
Dim oSSet As SelectSet
Dim dwodoc As DrawingDocument
Dim tmpsheet As Sheet
Dim PART_NAME As PartDocument
Set PART_NAME = ThisApplication.Documents(2)
Set dwodoc = ThisApplication.ActiveDocument
Set tmpsheet = dwodoc.ActiveSheet
Set oSSet = dwodoc.SelectSet
If oSSet.Count = 0 Then
MsgBox "PLEASE SELECT A VIEW"
Exit Sub
End If
Dim oView As DrawingView
Set oView = oSSet.Item(1)
If oView = kDrawingViewObject Then
Set pps = PART_NAME.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
pps("Description").Expression = "Sheet-15"
Else
MsgBox "WORKS ONLY ON DRAWING FILES"
End If
End Sub
Message 12 of 20
dgreatice
this my version.
Dim oApp As Application
Dim oDD As DrawingDocument
Dim oSht As Sheet
Dim oDV As DrawingView
Dim oReffDoc As Document
Dim oDwgPropSet As PropertySet
Dim oReffPropSet As PropertySet
Dim oDwgCustProp As Property
Dim oReffCustProp As Property
oApp = ThisApplication
oDD = oApp.ActiveDocument
oSht = oDD.ActiveSheet
oDV = oSht.DrawingViews(1)
oReffDoc = oDV.ReferencedDocumentDescriptor.ReferencedDocument
oDwgPropSet = oDD.PropertySets("User Defined Properties")
oReffPropSet = oReffDoc.PropertySets("User Defined Properties")
oDwgCustProp = oDwgPropSet("RBMATNO")
oReffCustProp = oReffPropSet("RBMATNO")
oDwgCustProp.Value = oReffCustProp.Value
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 13 of 20
Jesper_S
Hi.
I have used this iLogic codes.
To get iProperties from model to drawing.
If (ThisDrawing.ModelDocument Is Nothing) Then Return
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
'read the values from the Custom iProperties in the part file
'and apply them to the Custom iProperties with the same name in the drawing
iProperties.Value("Custom", "Header 1") = iProperties.Value(modelName, "Custom", "Header 1")
iProperties.Value("Project", "Part Number")=iProperties.Value(modelName, "Project", "Part Number")
iProperties.Value("Project", "Project")=iProperties.Value(modelName, "Project", "Project")
iProperties.Value("Summary", "Title")=iProperties.Value(modelName, "Summary", "Title")
And this to send iProperties from the drawing to the model.
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'Get the name Of the first model in the drawing
iProperties.Value(modelName, "Custom", "Header 1") = iProperties.Value("Custom", "Header 1")
iProperties.Value(modelName, "Project", "Part Number")=iProperties.Value("Project", "Part Number")
iProperties.Value(modelName, "Project", "Project")=iProperties.Value("Project", "Project")
iProperties.Value(modelName, "Summary", "Title")=iProperties.Value("Summary", "Title")
iLogicVb.UpdateWhenDone = True
Easy to add or remove iProperties you want to sync.
//Jesper
Message 14 of 20
andrescastellanosint
Hello, How do I run the rule for all drawing views of the sheet. Thanks
Message 15 of 20
A.Acheson
@andrescastellanosint Could explain the context of your request? The rule is intended to pick up the first model iproperties and apply to the title block with the same title block in all the drawing sheets. If you want to point to a different view you can use the longer API method shown here
and change the view number. Common practice is to have view 1 as the model reference.
Regards
Alan
Message 16 of 20
Hello, I am trying to extract information from the title block and add it to the name of the views. This rule only modifies one view for me.
I would like to be able to make a loop and be able to change the name of all the views.
Message 17 of 20
A.Acheson
In this case because the topic is very different I would suggest you to create a new post and check out those sample links.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/change-view-label/m-p/10560318#M1279...
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-change-view-label-properties/...
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-code-for-drawing-view-label-c...
Regards
Alan
Message 18 of 20
HI, thanks for the info, but I really need to get the property "Keywords" of Drawing not the models, and then copy it to the models property of all views.
Message 19 of 20
Curtis_Waguespack
Hi @andrescastellanosint,
I think this will do what you are asking.
I hope this helps.
Curtis
oKeywords = iProperties.Value("Summary", "Keywords")
Dim oDoc As DrawingDocument
oDoc = ThisDrawing.Document
Dim oModelDoc As Document
For Each oSheet In oDoc.Sheets
	oSheet.activate
	For Each oView In oSheet.DrawingViews
		oModelDoc = ThisDrawing.ActiveSheet.View(oView.Name).ModelDocument
		oModelDoc.PropertySets.Item(1).Item("Keywords").Value = oKeywords
	Next
Next
Message 20 of 20
it was exactly what i needed, Thanks
