External rule
External rule
External rule
Hi all,
I created an external rule but it is never executed (I put a message box to be sure).
Is an external rule must be called manually by a rule of the document?  Or I miss something?
Pascal
MegaJerk
Yes (as far as I know). There are a few ways to use external rules, but they all involve calling them from either rule that is in your model, by an event trigger, or manually.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Vladimir.Ananyev
You may start your rule from another iLogic rule using function
iLogicVb.RunExternalRule(path) .
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
