Get alignment type of an existing drawing view
erichter
erichter
I want to be able to get the alignment type (i.e. vertical, horiztonal, or positional) of an existing drawing view provided that it is aligned, but there doesn't seem to be a way to do this. DrawingView.Aligned only tells me if it's aligned, and DrawingViewAlignmentEnum seems to be write-only. I thought about comparing the position of DrawingView.ParentView, but the parent view is not necessarily the aligned view.
Does anyone know how I can get this?
JelteDeJong
You can check if there is a parent/child relationship between the views. If so then you can check by position. something like this:
Dim v1 As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select 1e view")
Dim v2 As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select 2e view")
If Not (v1.Aligned Or v2.Aligned) Then
    MsgBox("Not aligned ")
    Return
End If
If (v1.ParentView IsNot v2 And v2.ParentView IsNot v1) Then
    MsgBox("Not aligned (this is not a parent and a child view)")
    Return
End If
Dim alignment = ""
If (Math.Abs(v1.Top - v2.Top) < 0.0000001) Then
    alignment = "horizontal"
ElseIf (Math.Abs(v1.Left - v2.Left) < 0.0000001) Then
    alignment = "vertical"
Else
    alignment = "InPosition"
End If
MsgBox(String.Format(
        "There is a parent/child relation. Acc. to posistion they are {0} aligned.",
        alignment))
Jelte de Jong
Blog: hjalte.nl - github.com
erichter
I appreciate the suggestion, but I am trying to get the alignment type through selecting a single view only.
Also, if I am selecting two views, then I can check if one of them is aligned and evaluate their positional relationship regardless if they are a parent and child or not. A view having a parent view is independent from what view it's aligned to and thus irrelevant. I only mentioned it in the OP as something I tried but ruled out.
By selecting a single view, I would either like to know its alignment type or get the drawing view that it is aligned to so that I can compare their positions to determine the alignment type.
