General Table in .idw to grab custom iProperty in Part on Active Sheet
Lets say you have a part on your drawing and i want to add a 'general table,' however i want to add i new column to it with a custom iproperty from the part in the drawing can this be done?
bradeneuropeArthur
Convert the part to and I-part.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Set sh = b.Sheets.Item(1)
Dim v As DrawingView
Set v = sh.DrawingViews.Item(1)
Dim x As Document
Set x = v.ReferencedDocumentDescriptor.ReferencedDocument
MsgBox x.DisplayName
Dim tb As CustomTable
Set tb = sh.CustomTables.Item(1)
Dim c As Column
Dim t As Boolean
t = False
For Each c In tb.Columns
If c.Title = "YOUR COLUMN" Then
t = True
Next
If t = False Then
tb.Columns.Add ("YOUR COLUMN")
MsgBox tb.Columns.Item("YOUR COLUMN").Title
tb.Rows.Item(1).Item("YOUR COLUMN").Value = x.PropertySets.Item(4).Item(5).Value
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
