Frame Generator - Miter and cut detail - customized BOM
Message 1 of 26
Hi Guys,
This One is a good one for all you cleaver i Logic people.
I have a BOM that I want to use the Cutdetals from frame generator.
My need is for the figure of text that is created is not how my bosses want to use it.
The angle is created from the back edge of the box but typically the saw man will move the saw from 0 deg's which is 90 deg out from the the angle that inventor created. (hopefully you know what I mean)
so where Cutdetail says 51.33deg in my bom i want it to say 38.67deg.
first how would i do this???
also I want to bring the details into the Part number column to read as I have manually entered below.
Any Ideas on how to do this??
Replies (25)
Message 21 of 26
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try this.
Sub Main()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    ' Get the assembly component definition.
    Dim oAsmDef As WeldmentComponentDefinition
    oAsmDef = oAsmDoc.ComponentDefinition
    ' Get all of the leaf occurrences of the assembly.
    Dim oLeafOccs As ComponentOccurrencesEnumerator
    oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
    ' Iterate through the occurrences and print the name.
	Dim cnt As Integer
	cnt = 0
	Dim total As Double
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oLeafOccs
		If oOcc.DefinitionDocumentType = kPartDocumentObject Then
            Dim oReferDoc As PartDocument
            oReferDoc = oOcc.ReferencedDocumentDescriptor.ReferencedDocument
            Dim oProp As Inventor.Property
            For Each oProp In oReferDoc.PropertySets.Item(4)
                If oProp.DisplayName = "CUTDETAIL1" Then
					Dim oName As String
					oName = oProp.Name
                    Dim sawAngle As String
                    sawAngle = oProp.Value
					Dim angle(2) As String
					angle = sawAngle.Split(" ")
					If angle(0) = "Miter" Then
						Dim needAngle As Double
						needAngle = 90 - Convert.ToDouble(angle(1))
						oReferDoc.PropertySets.Item(4).Item(oName).Value = "Miter " + needAngle.ToString + " deg"
					End If
                End If
            Next
        End If
	Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 22 of 26
Hi Chandra,
This code appears to work perfect in our weldment template.
Message 23 of 26
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
If code is working, click on "Accept solutions"
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 24 of 26
BLA_fpineda
Hi @chandra.shekar.g
First of all, thank you for the solution it looks nice.
Let me say that once I executed the rule, the second time it does not update the information. It seems like the rule is not running.
Do you have any idea to fix that?
Thank you,
Message 25 of 26
CUT ANGLECUT ANGLE
hello
i write the rule in the assembly but it does not change the inverse angle on the BOM when i execute it
i'm french, i  replace 'CUTDETAIL1" by 'DETAILDECOUPE1' .....
Please could you help me.
i have ever write code in javascript and i don't  find console to execute the code and see if it works or executed and
you will find my assembly to see
Sub main()
    Dim oAsmDef As AssemblyComponentDefinition
	Dim cnt As Integer
	cnt = 0
	Dim total As Double
                 If oProp.DisplayName.Contains("DETAILDECOUPE2") = True Then
					Dim oName As String
					oName = oProp.Name
					Dim angle(1) As String
					Select Case angle(0)
					Case "Angle de coupe"
						If angle(2) <> 90 Then
						needAngle = 90 - Convert.ToDouble(angle(2))
						oReferDoc.PropertySets.Item(4).Item(oName).Value = "Angle de coupe " + needAngle.ToString + " deg"
					End If
					Case "Coupe d'onglet"
						If angle(1) <> 90 Then
						oReferDoc.PropertySets.Item(4).Item(oName).Value = "Coupe d'onglets " + needAngle.ToString + " deg"
					End If
                	End Select
				End If
            Next
        End If
	Next
End Sub
Message 26 of 26
DeanDavey
hi, how do you run this script?
Thank you!
