vb.net Message box with scrollbars
snappyjazz
snappyjazz
Hello. Newbie here. Using Inventor Pro 2019 with Visual Studio 2017. My script reads the content center child node levels and puts them in a LONG string; which is printed to a message box. Unfortunately because of the length of the string and no scroll bars, I can't see the bottom of the list. So I would like to pass the string to a secondary form that has a text box with scroll bars. I do not have enough experience with .net to get code snippets from the internet to work.  Do you know how to do this?
Module code:
Imports System
Imports System.Type
Imports System.Activator
Imports System.Runtime.InteropServices
Imports Inventor
Module Module1
    Sub Main()
        Dim invApp As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Dim invDoc As Inventor.Document = invApp.ActiveDocument
        'this gets all of the child nodes in the content center and puts them in a string list
        For Each Node1 As ContentTreeViewNode In TopNode.ChildNodes
            StrCCList &= Node1.DisplayName & vbNewLine
            For Each Node2 As ContentTreeViewNode In TopNode.ChildNodes.Item(Node1.DisplayName).ChildNodes
                StrCCList &= "   " & "   " & Node2.DisplayName & vbNewLine
                For Each Node3 As ContentTreeViewNode In TopNode.ChildNodes.Item(Node1.DisplayName).ChildNodes.Item(Node2.DisplayName).ChildNodes
                    StrCCList &= "   " & "   " & "   " & "   " & Node3.DisplayName & vbNewLine
                    For Each Node4 As ContentTreeViewNode In TopNode.ChildNodes.Item(Node1.DisplayName).ChildNodes.Item(Node2.DisplayName).ChildNodes.Item(Node3.DisplayName).ChildNodes
                        StrCCList &= "   " & "   " & "   " & "   " & "   " & "   " & Node4.DisplayName & vbNewLine
                    Next
                Next
            Next
        Next
        'reads the string list of the content center nodes
        'MsgBox(StrCCList)
        Dim FamResults As New FamResults(StrCCList)
        'FamResults.Activate()
        'FamResults.Show()
        'FamResults.TextBox1.Text = StrCCList
    End Sub
End Module
Secondary form code:
Public Class FamResults
    Public Sub New(ByVal PropSetString)
        ' This call is required by the designer.
        InitializeComponent()
        ' Add any initialization after the InitializeComponent() call.
    End Sub
    Private Sub TextBox1_TextChanged(sender As Object, e As EventArgs) Handles TextBox1.TextChanged
        'Dim TextOutput As String = sender
        'Dim TextOutput As String = "Family Results popup dialog"
        'MsgBox(TextOutput)
        'TextBox1.Text = TextOutput
    End Sub
    Private Sub ExitButton_Click(sender As Object, e As EventArgs) Handles ExitButton.Click
        Me.Close()
    End Sub
End Class
snappyjazz
I figured it out. In the section of code below is where I went wrong.
        FamResults.Show()
  • First of all, I/you don't need the ".Activate()".
  • Secondly, ".Show" is a modeless call to show a form. In this case, the main script is running simultaneously to the code in the form(FamResults). The result is the main script finishes and closes the program before the form has a chance to appear.
  • The fix is to use ".ShowDialog()" which opens the form as modal. Which will pause the main script while the form is open. Upon closing the form then the main script will finish/close.
  • Third of all "FamResults.TextBox1.Text = StrCCList" needs to be moved above the ".ShowDialog()"
The result is that the script gets all of the levels of the content center and puts them in a string (a long string). This string is then put in the text box of a form with scroll bars, so you can scroll down and see the whole hierarchy.
Final Code:
Imports System
Imports System.Type
Imports Inventor
Module Module1
    Sub Main()
        Dim ConCen As ContentCenter = invApp.ContentCenter
        Dim TopNode As ContentTreeViewNode = invApp.ContentCenter.TreeViewTopNode
        Dim StrCCList As String = "   " & "   " & "   " & "   " & "   " & "Content Center Breakdown" & vbNewLine
                    Next
                Next
            Next
        Next
        Dim FamRes As New FamResults(StrCCList)
        FamRes.TextBox1.Text = StrCCList
        FamRes.ShowDialog()
    End Sub
End Module
    End Sub
    End Sub
        Me.Close()
    End Sub
End Class
PS. You have to have an .ipt open for this to get the Content Center. I don't have the skill yet to check if an .ipt is open.
