Forms display different in visual studio and when I call in inventor
edson_luiz86
edson_luiz86
Hello everyone,
Anyone have this issue with windows forms, when I run directly in visual studio the forms is showed right, but when I call by inventor document, the forms is show in other resolution.
Forms directly from Visual Studio
Forms directly from inventor document
Sometimes, textboxes is hidden in flowPanels
Best regards,
Edson Luiz Candido
bradeneuropeArthur
Has to do with the 4k resolution. Possibly inventor is still not 4k ready completely.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
edson_luiz86
I have two screens, one with 1920x1080 (zoom 125%), other is 1280x1024 (zoom 100%)
i think the error is because zoom monitor, but I do not know to force windows form to not zoom it.
Best regards,
Edson Luiz Candido.
marcin_otręba
take a look at autoscalemode property for your form.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
edson_luiz86
I try to change the autoscale property to Dpi or None, but when I call the dll with form the form is rendered with some scale and some inputs was hidden, I solved this recalculating the flow panel height by count controls inside it and resize on form load. But this is a annoyng, so for the next project I will use WPF.
