form design tree picture
SpokenEarth
SpokenEarth
Is it possible to attach pdf to a window form design tree?
SpokenEarth
CCarreiras
Hi!
you cannot attach the pdf file in the form, but you can create a rule to open the pdf and place the "rule button" in the form, which gives you the same final result... open the pdf.
CCarreiras
SpokenEarth
Thanks, could you perhaps assist me by provide a code?
Curtis_Waguespack
Hi  @SpokenEarth
You can open any document with something like this.
ThisDoc.Launch("C:\Temp\My PDF.pdf")
As mentioned you can add this to a rule and then add that rule to your form as a button.
I hope this helps.
Curtis
SpokenEarth
Thank you Curtis.
Achilles
