I logic for derived part
didin.suryadi6JREK
Message 1 of 17
didin.suryadi6JREK
I have below i-logic to delete the specific user parameters on the part, But somehow it doesn't work for the derived part.
(the part with 2d file referenced), Is there any additional logic to add to make both are working?
'------- @_@ start of ilogic @_@ ------
Dim oDoc As PartDocument = ThisDoc.Document
Dim doc = ThisDoc.Document
For Each oParam As Parameter In doc.componentdefinition.Parameters.UserParameters
oParam.Delete
Next
I think the problem is on "ThisDoc" when it hits another source.
Replies (16)
Message 2 of 17
A.Acheson
This post semi deals with the situation your looking at. Nothing was marked as solved but I believe the VBA at the end has worked. The term delete may not be correct as you are just unlinking from the parent file so as such need to either include or exclude the parameter.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/deleting-derived-parameters-that-are-no...
Regards
Alan
Message 3 of 17
didin.suryadi6JREK
Thanks for the idea, Could you please check wheater the below arrangement is correct or not?
	oParam.Delete
Next
For Each oDerivedParameter As DerivedParameter In DerivedParameterTable.DerivedParameters
If Not oDerivedParameter.InUse Then oDerivedParameter.Delete
Next
The Error msg shown like below:
Rule Compile Errors in Conversion Rule Part, in Test.ipt
Error on Line 8 : Reference to a non-shared member requires an object reference.
Message 4 of 17
A.Acheson
Here is a working rule to derive all parameters from the base component to a derived part file.
You can put in filters if you want to target only specific parameters to include/exclude. I would suggest use it on a sample file as it could really mess up the part until your sure of it's function.
I found this rule from here,  I just removed it from the for loop for the assembly document it was been used in.
Change this line "oDPEnt.IncludeEntity = True 'True to include, False to exclude!" to control the parameters included /excluded .
Dim doc As Document = ThisDoc.Document
	If doc.DocumentType = 12290 Then 'part file
		Dim oDPComp As DerivedPartComponent
		Dim oDPComps As DerivedPartComponents
		oDPComps = doc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
			For x = 1 To oDPComps.Count
				oDPComp = oDPComps.Item(x)
				Dim oDPDef As DerivedPartUniformScaleDef = oDPComp.Definition
				Dim oDPEnts As DerivedPartEntities = oDPDef.Parameters
				Dim oDPEnt As DerivedPartEntity
					'Loop to include/exclude parameters
					For Each oDPEnt In oDPEnts
						'Filter for specific parameter
						'If oDPEnt.ReferencedEntity.Name = "Length" Then ' Add your parameter name here!
							'Exit For
						'End If
					Next
			oDPComp.Definition = oDPDef
			Next
Regards
Alan
Message 5 of 17
didin.suryadi6JREK
The code works fine but somehow when I run it on the derived part it's taking longer than I thought.
It's was finished about 50 secs to 1 minute of executing the base part.
Can we push the speed of the time to be faster?
Appreciated your prompt response.
Message 6 of 17
A.Acheson
I didn’t see any issues on my side, I had 5 parameters and ran the rule looked in the parameters dialogue and they were done, I used single value parameters. Can you try a message box or a log info message at each stage to check progress. There must be a logical  reason it took so long to execute. Please supply the full rule if placed inside a larger rule.
Regards
Alan
Message 7 of 17
didin.suryadi6JREK
Below are the complete codes, Could you please check?
I don't understand why the error msg comes when I ran the codes.
oParam.Delete
Next
							'Exit For
						'End If
					Next
			Next
Message 8 of 17
A.Acheson
The error I believe is coming when your looking to delete the user parameters from the child document. oParam was declared as a Parameter in the User parameter collection. As it was there was no delete function as your looking for the wrong object in that collection. If you declare oParam as a UserParameter the delete function is accessible.
This is a good example of declaring variables starting with the document and checking what is available after declaring.
Dim doc As PartDocument = ThisDoc.Document
For Each oParam As UserParameter In doc.componentdefinition.Parameters.UserParameters
oParam.Delete
Regards
Alan
Message 9 of 17
didin.suryadi6JREK
Hi
Sorry for not being clear on this
Actually, I have the previous codes with oDoc to be included, so Both are needed.
How's that possible to combine Doc and oDoc I with the same i-logic codes?
Could you please review the below codes? I ran it and still error, the error msg is the same.
oParam.Delete
Next
'Exit For
'End If
Next
Next
'Next 'Derived part componen
'define custom property collection
Dim customPropertySet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
'look at each property in the collection
For Each oCustProp In customPropertySet
'delete the custom iProperty
oCustProp.Delete
Next
Dim propertyName1 As String = "Rev Note"
Dim propertyValue1 As String = ""
Try
prop = customPropertySet.Item(propertyName1)
Catch
customPropertySet.Add("", propertyName1)
End Try
Dim propertyName2 As String = "Revision Date"
Dim propertyValue2 As Nullable(Of Date) = Date.Now
Dim NullDate As Nullable(Of Date)
Try
prop = customPropertySet.Item(propertyName2)
Catch
customPropertySet.Add(propertyValue2, propertyName2)
iProperties.Value("Custom", propertyName2) = NullDate
End Try
Dim propertyName3 As String = "Bending Proficient"
Dim valString As String = InputBox("BendingProficient:", "Set Property", "No")
Dim propertyValue3 As Boolean = If (valString = "Yes", True, False)
Try
prop = customPropertySet.Item(propertyName3)
Catch
prop = customPropertySet.Add(propertyValue3, propertyName3)
End Try
iProperties.Value("Custom", propertyName3) = propertyValue3
Dim propertyName4 As String = "ECN_date"
Dim propertyValue4 As Nullable(Of Date) = Date.Now
Try
prop = customPropertySet.Item(propertyName4)
Catch
customPropertySet.Add(propertyValue4, propertyName4)
iProperties.Value("Custom", propertyName4) = NullDate
End Try
Dim propertyName5 As String = "ECN_ENGINEER"
Dim propertyValue5 As String = ""
Try
prop = customPropertySet.Item(propertyName5)
Catch
customPropertySet.Add(propertyValue5, propertyName5)
End Try
Dim propertyName6 As String = "ECN_NUMBER"
Dim propertyValue6 As String = ""
Try
prop = customPropertySet.Item(propertyName6)
Catch
customPropertySet.Add(propertyValue6, propertyName6)
End Try
Dim propertyName7 As String = "GRAIN_LENGTH"
Dim propertyValue7 As String = "=<Sheet Metal Length>"
Try
prop = customPropertySet.Item(propertyName7)
Catch
customPropertySet.Add(propertyValue7, propertyName7)
End Try
Dim propertyName8 As String = "GRAIN_WIDTH"
Dim propertyValue8 As String = "=<Sheet Metal Width>"
Try
prop = customPropertySet.Item(propertyName8)
Catch
customPropertySet.Add(propertyValue8, propertyName8)
End Try
Dim oUM As UnitsOfMeasure = oDoc.UnitsOfMeasure
Dim oLengthUnits As String = InputBox("Length units:", "Masukan Unit Length", oUM.GetStringFromType(oUM.LengthUnits))
Try
oUM.LengthUnits = oUM.GetTypeFromString(oLengthUnits)
Catch
MessageBox.Show("""" & oLengthUnits & """"& " is not a valid length units", "Input Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Dim oMassUnits As String = InputBox("Mass units:", "Masukan Unit Massa", oUM.GetStringFromType(oUM.MassUnits))
Try
oUM.MassUnits = oUM.GetTypeFromString(oMassUnits)
Catch
MessageBox.Show("""" & oMassUnits & """"& " is not a valid mass units", "Input Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Dim oMaterials As New List(Of String)
Dim oActiveMaterial As String = oDoc.ActiveMaterial.DisplayName
For Each oMaterial As MaterialAsset In ThisApplication.ActiveMaterialLibrary.MaterialAssets
oMaterials.Add(oMaterial.DisplayName)
Next
If oMaterials.Contains(oActiveMaterial) = False Then oMaterials.Add(oActiveMaterial)
oMaterials.Sort
Dim selectedMaterial As String = InputListBox("Pilih material", oMaterials, oActiveMaterial)
Try
oDoc.ActiveMaterial = ThisApplication.ActiveMaterialLibrary.MaterialAssets.Item(selectedMaterial)
Catch
End Try
iProperties.Value("Summary", "Author") = ThisApplication.UserName
iProperties.Value("Project", "Revision Number") = InputBox("Revision Number:", "Set Property", "-")
iProperties.Value("Project", "Designer") = ThisApplication.UserName
iProperties.Value("Project", "Engineer") = ThisApplication.UserName
iProperties.Value("Project", "Creation Date") = Today
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
myMass = iProperties.Mass
MessageBox.Show("Mass = " & myMass, "iLogic")
When i skip the deletion (like in the below) then it works.
'oParam.Delete
Message 10 of 17
A.Acheson
You can just change the part document name to whatever is the most used for document variable in your codes, use find and replace to replace them.
So change doc to oDoc. It has been declared twice which isn't necessary.
And if you want to check the document is a part move the if statement outside of the main body of the rule. It is just there for good practice and isn't totally needed, the below methods are where you can find the information on that and how you can implement this.
Method 1
'Declare this document
Dim doc As Document
'Check if we have a part document
'Make the document before checking equal to document after checking
	oDoc = doc
	'*** Insert  stuff here
Else
	MessageBox.Show("This is not a Part Exiting!", "Title")
Method 2:
 Dim doc As Document
If doc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
oDoc = doc Else '*** Insert stuff here MessageBox.Show("This is not a Part Exiting!", "Title") End If
Method 3:
'Declared Document as Part Document, it will error out if not a part document
 oDoc = ThisDoc.Document
Regards
Alan
Message 11 of 17
didin.suryadi6JREK
hi
I tried all of your three methods but the errors are still coming, some of them seem the arrangement was wrong. Could you please check the complete codes? I just wondering why the codes are working when I turn off "oParam.Delete" ... Below Codes is working, but when i turn the on the "oParam.Delete" , the msg error is come.
'oParam.Delete
Next
							'Exit For
						'End If
					Next
			Next
oCustProp.Delete
Next
Dim propertyName1 As String = "Rev Notes"
Try
Catch
End Try
Try
Catch
End Try
Dim valString As String = InputBox("Salvagnini Proficient:", "Set Property", "No")
Try
Catch
End Try
Dim propertyName4 As String = "ECN_DATE"
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Next
oMaterials.Sort
Try
Catch
End Try
Message 12 of 17
A.Acheson
As long as you are deleting user parameters you can use this snippet referred to in Message 8
For Each oParam As UserParameter In oDoc.componentdefinition.Parameters.UserParameters
oParam.Delete
 Or if you want to target all of the parameters you can use
'Loop Document and target all parameters
For Each oParam As Inventor.Parameter In oDoc.ComponentDefinition.Parameters
oParam.Delete
Next
Error in Targeting a User Parameter collection as a Parameter Object
As you can see if your in the wrong collection or haven't declared the object correctly, Delete is not available to you.
Regards
Alan
Message 13 of 17
didin.suryadi6JREK
I really dont know how to solve this, When i saved the codes was working. But when it ran shows the error msg:
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.Parameter.Delete()
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 14 of 17
A.Acheson
I would suggest step through the code with a message box and switch of section of code where you think error might have occurred. It looks like parameter is being mentioned in the error message. Perhaps an error trap is needed in that area. I will be able to take a look at this tomorrow.
Regards
Alan
Message 15 of 17
A.Acheson
Here is the rule that works for me, it is ran in an external rule and with Inv 2020
 Dim doc As Document
		oDoc = doc
	For Each oUserParam As UserParameter In oDoc.ComponentDefinition.Parameters.UserParameters
	oUserParam.Delete
	Next
	oDPComps = oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
						'Exit For
					'End If
				Next
		Next
	oCustProp.Delete
	Next
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Try
	Catch
	End Try
	Next
	oMaterials.Sort
	Try
	Catch
	End Try
Else
Regards
Alan
Message 16 of 17
didin.suryadi6JREK
Waw..
Thank You very much, Now is working.
Message 17 of 17
A.Acheson
Glad to hear it’s working👍Only a few minor tweaks were needed. A good learning exercise.
Regards
Alan
