Force Model Browser to update with new geometry
AlexFielder
Advisor Advisor
AlexFielder
Related to this other post I have managed to get the resultant hole features created correctly based on the axes that intersect with the workpoints created by that method, but one thing that I cannot fathom is why these new features don't show up in the Model Browser until I close and reopen the file.
I have tried:
partDoc.Update();
RadialHoles.m_InventorApp.ActiveView.Update();
as well as:
private static void updateBrowserPane()
BrowserPane pane = partDoc.BrowserPanes.ActivePane;
pane.Update();
None of which seem to work.
It's probably something dead simple but I was hoping that someone else has experienced this and might be able to share the answer.
Alex.
GeorgK
Hello Alex,
does it help to change the browserpane?
    Dim invDoc As Document
    Set invDoc = ThisApplication.ActiveDocument
    If invDoc Is Nothing Then
        MsgBox "No documents open!", vbOKOnly
        Exit Sub
    End If
    If invDoc.DocumentType <> kAssemblyDocumentObject Then
        MsgBox "Active document is not an assembly model!", vbOKOnly
        Exit Sub
    End If
    Dim invModelTree As BrowserPaneObject
    Set invModelTree = invDoc.BrowserPanes.Item("AmBrowserArrangement")
    Dim OccBrowserNode As BrowserNode
    Dim LabelName As String
    Dim DocName As String
    invModelTree.Activate
    invModelTree.Refresh
    invModelTree.Update
Georg
AlexFielder
Hi @GeorgK,
Unfortunately, that doesn't help me since I am working in a part file and the .Refresh throws an error as a result.
Alex.
wayne.brill
Hi Alex,
The holes that are created with the code I have show up instantly in the browser.
I can research the problem you are seeing. Can you provide a small but complete code example that will allow me to recreate the behavior where the hole features are showing in the browser only after the file is re-opened?
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
AlexFielder
Hi @wayne.brill,
After looking at this with fresh eyes, I revisited my code and removed a transaction that I had set up to effectively "end" after having placed the sketch points.
I can't really fathom why I had it there in the first place, but, after making this change:
public static void Button1_Execute()
            log.Info("Radial Holes button was clicked!");
            Transaction trans = RadialHoles.m_InventorApp.TransactionManager.StartTransaction(RadialHoles.m_InventorApp.ActiveDocument, "Radial Holes");
            reporter.UpdateStatusBar("Hello from the first button extension!");
            try
                GetExcelData();
                if (selectedAFaceAnAxisAndPlane())
                    checkForAndClearExistingAttributes();
                    createSketchForPoints();
                    createSketchPointsFromList();
                    createGeomForHolePositions();
                    createHolesFromDefinitions();
                    updateBrowserPane();
                    //createWorkAxesForHolePoints();
            catch (Exception ex)
                trans.Abort();
                log.Error(ex.Message);
                NullAllTheThings();
            finally
                trans.End();
                if(reporter != null)
                    partDoc.Update();
                    NullAllTheThings();
                log.Info("Radial Holes completed.");
Wherein the transaction wraps the whole process, all newly created features appear as expected.
It was you assertion that the code you had worked without issue that sparked the light-bulblight-bulb-32x32.png in my head to say "try it without the transactions in the middle" which solved it so Thank you!
