Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
For Each Loop in iLogic Rule
ulasdeniz
Mentor Mentor
ulasdeniz
Hi. I am new in visual basic. I am trying to automatically create a list of parts that are changing dimensions by a parameter. So I need a for loop to change the parameter and save the file for each value in the list.  (this is just a first step, in second step I will create a nested loop.)
I tried to write a rule but it doesnt work. Can you help me?
SyntaxEditor Code Snippet
    For Each index In  {2, 4, 6}
        BB = index * 10
    iLogicVb.UpdateWhenDone = True
    ThisDoc.Document.SaveAs("dd" & ".ipt" , False)
    Next
Ulaş Deniz
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ( "ACCEPT AS SOLUTION" ) seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" (KUDO) ile ödüllendirin.
Youtube : https://www.youtube.com/channel/UCkJpVueGScmJvW1RIgqttSg
MechMachineMan
If you can post screenshots of the error windows that is always useful for us to diagnose what is wrong.
For additional iLogic/vb.net info check out the blogs:
http://beinginventive.typepad.com/being-inventive/
http://adndevblog.typepad.com/manufacturing/
http://modthemachine.typepad.com/my_weblog/
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
ulasdeniz
Thank you. the errors are in below When I delete the update and save as rows (last two rows before the Next statement) the rule works and model parameter is changing.
Ulaş Deniz
MechMachineMan
As you can see i the second window, working from the bottom up, we see the issue goes from iLogic (which is the add-in) > ExecRuleInAssembly (The active assembly file) > Main (the rule in the assembly) > Document.SaveAs (A line/function trying to be performed by the Rule) > ForwardCall (the exact problem the program is running into).
From the last 2 things listed (or the first 2 from the top in the window) we can see it is an issue with the same (why you see SaveAs in there) and an issue with something we don't know (forwardcall - upon research, you will find this actually has to do with calling an invalid variable as a parameter).
From experience, the examples in the API help, and help in the forums, I have learned this specific situation is caused by the fact that you don't have the full file string listed in your saveas arguements. You need a string such as: "C:\Users\Bob\File.ipt"
Justin K
ulasdeniz
Thank you. İt is solved as you stated. Full path name is rrequired. some functions doe not require the path name as using the current document path.
But I have enother problem. My code is working, the parameters are changed. but the prametric flush constraint couldnt changed. I did everything. Document update. Add flush constraint's dimension into code and connected to the index parameter, placing update statement every row where the model is changed. But ı couldnt solved this.
Ulaş Deniz
Z0methink
'This Is code for changing the parameters of components from an assembly.
'If there Is no such parameter in the component, then the error Is ignored.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisDoc.Document
Dim  oAsmCompDef As  AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
Parameter.Quiet = True
For Each occComp As Inventor.ComponentOccurrence In oAsmCompDef.Occurrences
	Parameter(occComp.Name, "d0") = d0
	Parameter(occComp.Name, "d1") = d1
	Parameter(occComp.Name, "d2") = d2
Next
Parameter.Quiet = False
