Foldername to Project ipropertie
jostroopers
Message 1 of 8
jostroopers
I make a copy design from vault basic.
I open the main assy and with a rule I want to have the folder name, 202020, taken over by the ipropertie Project.
Is this possible with an ilogic code?
Can / will someone help me with that?
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
Replies (7)
Message 2 of 8
FINET_Laurent
Morning,
I suppose there is a quicker way to this but here is my go :
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oDocPath As String = oDoc.FullFileName
Dim oDocName As String = oDoc.DisplayName
	Dim oDocPath2 As String = Split(oDocPath, "\" & oDocName)(0)
		Dim FolderName As String = oDocPath2.Remove(0, oDocPath2.LastIndexOf("\") + 1)
iProperties.Value("Project", "Project") = FolderName
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 8
bradeneuropeArthur
Edit.
I understood wrong!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 8
jostroopers
Thanks Finet.
How will it go if I create some subfolders in the root folder 202020.
I still want the iproperty to point to the root directory.
So if I put a model in the folder 163000 and 163005, the iproperty, Project, should still take the value 202020 in these models.
Mvg Jos
Message 5 of 8
FINET_Laurent
This whould go like this :
		Dim FolderName As String = oDocPath2.Remove(0, oDocPath2.LastIndexOf("\"))
			Dim oDocPath3 As String  = Split(oDocPath2,FolderName)(0)
				Dim FolderName2 As String = oDocPath3.Remove(0, oDocPath3.LastIndexOf("\") + 1)
iProperties.Value("Project", "Project") = FolderName2
The thing is, you need 2 rules for both cases... Is it an issue in your case ?
If yes you might need to take a different aproach.
FINET L.
Message 6 of 8
jostroopers
@FINET_Laurent Super thanks.
This is no problem. If I have one model in an order, I use rule number 1. If I have several models that are placed in subfolders in an order, I use rule number 2.
Kind Regards.
Mvg Jos
Message 7 of 8
FINET_Laurent
@jostroopersGlad I could help 😄 !
Message 8 of 8
jostroopers
@FINET_Laurent
I made a change and now the second code is not working.
Instead of the folder 163000 I now use 02_9_Vast Daklicht.
Now the ipropertie 'Project' gets the value 02_9_Vast Daklicht instead of 202020.
Is that because of the different value of the sub folder?
Mvg Jos
