Flat pattern save copy as dxf
I'm having issues with performing an export/save copy as with a sheetmetal part that has a flatpattern to dxf, the dxf file always ends up corrupt.
I'm using .ini file generated from the regular save copy as -> configuration on a flat pattern. And my code follows somewhat the API example.
Is it even possible to export the flatpattern with these .ini files? What am i missing?
Code:
TranslatorAddIn translatorAddin = null;
TranslationContext translationContext = Application.TransientObjects.CreateTranslationContext();
translationContext.Type = IOMechanismEnum.kFileBrowseIOMechanism;
NameValueMap options = Application.TransientObjects.CreateNameValueMap();
DataMedium dataMedium = Application.TransientObjects.CreateDataMedium();
var sheetMetalDxf = filetypeBase as SheetMetalDXF;
translatorAddin = (TranslatorAddIn)Application.ApplicationAddIns.ItemById["{C24E3AC4-122E-11D5-8E91-0010B541CD80}"];
if (sheetMetalDxf.UseSettingsFile)
    if (sheetMetalDxf.SettingsFile != "")
        options.set_Value("Export_Acad_IniFile", sheetMetalDxf.SettingsFile);
dataMedium.FileName = Path.GetFileNameWithoutExtension(document.FullFileName);
translatorAddin.SaveCopyAs(document, translationContext, options, dataMedium);
- Anders Hansson
Maxim-CADman77
I wonder - was it ever solved?
Please vote for Inventor-Idea Text Search within Option Names
