Ilogic drawing dimension object
Hi, I am trying to get the ModelValue of a dimension on a drawing.
I can select the dimension and add some custom text to this. At the same time I would like to read the ModelValue and export this to a custom parameter.
Would anyone be able to help?
thanks,
Stuart
RodrigoEiras
Hi Stuart,
The syntax to do that is not complicated, and it is shown below. There are two tricky things to take into account:
1.- ModelValue is given in Inventor Database units, which are cm for distance, rad for angles, ..
Inventor internally always uses cm (centimeters) for length, radiansfor angle, kg (kilograms) for mass and seconds for time
2.- You may want to know what type of dimension you are dealing with to anticipate the units, so maybe you have to check the dimension type to see if it is linear, angular, ... That you can do through oDrawingDimension.Type
I hope this helps!
SyntaxEditor Code Snippet
oDrawing = ThisDrawing
oSheet = ActiveSheet.Sheet
For Each oDrawingDimension In oSheet.DrawingDimensions
    Trace.writeline(oDrawingDimension.ModelValue)
    ParameterX = oDrawingDimension.ModelValue
Next
Hi Rodrigo,
Thats been a great help thanks!
It took a little bit of work to get it to write the selected dimension and convert to the correct unit, but it does just what i need now
It was the trace.writeline i was missing for the best part.
thanks again for your  help.
Stuart
