- Mute
- Permalink
- Report
I have an Assembly with multiple levels. I try to find if a part is in front of an other part with the FindByUsingVector methode. This seems to work on the first and second level, but when I shoot the vector from a part in a sub-sub assembly (third level) it does not see the other parts that are in a higher assembly...?? is there some limitation?
I use the ComponentDefinition of the main assembly
also I tried changing the option filter but that did not help. I use kPartFaceFilter and kAssemblyOccurrenceFilter.
should I maybe use the FindByUsingRay methode? what is the difference between the two?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated
Succes on your project, and have a nice day
Herm Jan
Herm Jan
