How do i automate clicking a square in a 2d sketch to make a larger square that offsets the original and makes corner cutouts?
I was able to command-bash macros in excel using the macro recorder.
However inventor doesnt have any such function, im wondering how i would write a macro that does this.
The steps are:
1. Run Macro
2. Select a square/rectangle
3. This triggers the macro to use Offset command to create a square/rectangle with sides that are .001" equidistant
4. Draw circles (0.06") at each of the four corners of the offset square/rectangle
5.Done
Currently i can see how steps 1 and 5 would work with everything else being a blackbox. If anyone can guide me to a sample code that mimicks what I need, I could probably stumble my way to a solution.
Thanks!
JelteDeJong
try this. its not the best code but i quess its a good start. (also have a look at the comments in the code) you can use it by running the ilogic code. then select a sketch (with a square) then select the square. And look what happens.
Dim doc As PartDocument = ThisDoc.Document
Dim sketch As PlanarSketch = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select a sketch") sketch.Edit() 'selecting a square/rectangle is not an option that i could find. but you could select a profile. 'i use it here but it will only work if there is none geometry inside the square/rectangle Dim profile As Profile = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchProfileFilter, "select a square/rectangle") Dim objs As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection() Dim cornerPoints As List(Of Point2d) = New List(Of Point2d)() For Each path As ProfilePath In profile For Each ent As ProfileEntity In Path objs.Add(ent.SketchEntity) cornerPoints.Add(ent.StartSketchPoint.Geometry) cornerPoints.Add(ent.StartSketchPoint.Geometry) Next Next ' You need to use CM for distances Dim offsetEnts As SketchEntitiesEnumerator = sketch.OffsetSketchEntitiesUsingDistance(objs, 0.01 * 2.54, False) For Each ent As SketchEntity In offsetEnts sketch.SketchCircles.AddByCenterRadius(ent.StartSketchPoint.Geometry, 0.06 * 2.54 / 2) Next ' uncomment this lines if you want the cicles on the inner square 'For Each cornerPoint As Point2d In cornerPoints ' sketch.SketchCircles.AddByCenterRadius(cornerPoint, 0.06) 'Next
Jelte de Jong
Blog: hjalte.nl - github.com
Thanks @JelteDeJong ! Illtry it out at work, this will give me a good base to go off of
