Finding feature name from a view in an idw
MichaelLockhart3046
MichaelLockhart3046
Hi all,
I've got iLogic code working such that I can loop through all the holes in my idw. I was wondering if there was a way to find the feature name of a specific hole in a drawing.
For example: This hole would tell you its part of the "Hole3" feature
Any help would be appreciated
A.Acheson
Can you post the code your working with?
Regards
Alan
MichaelLockhart3046
Sub Main()
	oDocument = ThisDoc.Document
	ShNum  = Mid(oDocument.ActiveSheet.Name, InStr(1, oDocument.ActiveSheet.Name, ":") + 1)
	Dim oDrawDoc As DrawingDocument
		oDrawDoc = ThisApplication.ActiveDocument
	Dim oSketch As DrawingSketch
		oSketch = oDrawDoc.ActiveSheet.Sketches.Add
	oSketch.Edit
	Dim oTG As TransientGeometry
		oTG = ThisApplication.TransientGeometry
	Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select Drawing View")
	Dim oTO As TransientObjects = ThisApplication.TransientObjects
	Dim oScale As Double = oView.Scale
	For Each oCurve As DrawingCurve In oView.DrawingCurves
		Try
			If oCurve.CurveType = kCircleCurve Then
				Dim oDia As Double = oCurve.Segments.Item(1).Geometry.Radius * 2 * 10 / oScale
				If IsEqual(oDia, 4)
					x = oCurve.CenterPoint.X
					y = oCurve.CenterPoint.Y
					txtbx = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(x-0.3, y + 0.35), "S12")
					txtbx.Style.FontSize = 0.23
				End If
			End If
		Catch
			'MsgBox("Error")
		End Try
	Next
	' Exit the sketch from the edit environment.
	oSketch.ExitEdit
End Sub
Function IsEqual(Value1 As Double, Value2 As Double, _
	Optional Tolerance As Double = 0.000001) As Boolean
	If Abs(Value1 - Value2) < Tolerance Then
		IsEqual = True
	Else
		IsEqual = False
	End If
End Function
I am trying to change the IsEqual function with matching a feature name instead
JhoelForshav
Hi @MichaelLockhart3046
I don't know if you want the code to write the feature name in the holes or if you just want to compare the feature name to a string with your IsEqual-function. I've edited the code for both scenarios.
Write name of feature in hole:
Sub Main()
oDrawDoc = ThisDoc.Document
oSketch.Edit
	Try
			Dim oEdge As Edge = oCurve.ModelGeometry
			If oEdge IsNot Nothing
				For Each oFace As Face In oEdge.Faces
					If TypeOf (oFace.CreatedByFeature) Is HoleFeature
						txtbx = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(x, y), oFace.CreatedByFeature.Name)
						txtbx.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter
						txtbx.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle
					End If
				Next
			End If
		End If
	Catch
		'MsgBox("Error")
	End Try
Next
oSketch.ExitEdit
End Sub
Compare feature name to string with function:
Sub Main()
oSketch.Edit
	Try
				If IsEqual(oEdge, "Hole1")
					txtbx = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(x, y), "S12")
				End If
			End If
		End If
	Catch
		'MsgBox("Error")
	End Try
Next
oSketch.ExitEdit
End Sub
Function IsEqual(oEdge As Edge, fName As String) As Boolean
		If oFace.CreatedByFeature.Name = fName Then Return True
	Next
	Return False
End Function
I hope one of them is what youre looking for 🙂
MichaelLockhart3046
This is exactly what I needed! Works amazing, thanks
