Remove symbol from all open drawings
So I am trying to make a code where if there is multiple drawings open, the code will start with the left 'tab' drawing, locate a specific symbol, remove it, move to the next drawing, remove it and so on until all symbols have been removed. The pages dont even have to shift, as long as it batch removes that specific symbol from all open drawings on Inventor, I am happy. I am really new to coding so sorry if it doesnt make sense or is really easy to do.
This is what I have written so far:
For Each doc As Document In ThisApplication.Documents.VisibleDocuments
For Each oSymbol In oDrawDoc.VisibleDocuments.SketchedSymbols
	'look for the symbol by name
	If oSymbol.Name = "WARNING" Then
		oSymbol.Delete
Next
A.Acheson
You will need to look only at the drawing document then in the sheet collection then loop over each sheet and delete the symbol then you can delete the symbol from the document. I have tested the below but as always open a sample drawing and test.
	'Filter by document type Drawing
	If doc.DocumentType = kDrawingDocumentObject Then
	'MessageBox.Show(doc.FullFileName, "Title")
		Dim oSheets As Sheets
		Dim oSheet As Sheet
		oSheets = doc.Sheets
		'Loop through each sheet
		For Each oSheet In oSheets
			'Loop through each symbol in the active sheet
			For Each oSymbol In oSheet.SketchedSymbols
				'look For the symbol by name
					oSymbol.Delete
			Next
			'Delete symbol in the document after all symbols have been removed from the sheets
			Try
			Dim oSketchedSymbolDef As SketchedSymbolDefinition
			 oSketchedSymbolDef = doc.SketchedSymbolDefinitions.Item("WARNING")'Symbols
			oSketchedSymbolDef.Delete
			Catch
			End Try
		Next
Next
Regards
Alan
That worked perfectly, thanks heaps for the help!
