find rev number from 3d part insted of 2d?
Darkforce_the_ilogic_guy
Advisor Advisor
oRevNum = iProperties.Value("Project", "Revision Number")
 I uses the code about to find the Rev. Number of an drawing... I want it to find the form the 3d model(ipt, iam) that are use on the drawing . but the code is run on the 2d (idw).
How do i get that ?
FINET_Laurent
Hi, The same way I suppose.. :
"Project" , "Revision number"
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Ralf_Krieg
Hello
Am I right you want the revision number of the 3d model referenced in your drawing? The code below get's it for the first referenced document.
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
Dim oRefedDoc As Document = oDrawDoc.ReferencedDocuments.Item(1)
Dim oProp As Inventor.Property = oRefedDoc.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").Item("Revision Number")
MsgBox (oProp.Value)
R. Krieg
RKW Solutions
www.rkw-solutions.com
That is what I needed ... Thanks
