Find iProperty
Find iProperty
johnster100
Find iProperty
johnster100
i'm reading in iproperty names and values from a spreadsheet.
My issue is when i read them in i don't know which propertyset they belong to.
What is the best way to find an iproperty when you don't know it's property set?
thanks,
John
Curtis_Waguespack
Hi @johnster100
You could use something like this, where sPropertyName contains the iProperty name that you read in from Excel.
I hope this helps.
Curtis
sPropertyName = "Part Number" 'this is the varaible read in from Excel
' Get the active document.
Dim invDoc As Document
invDoc = ThisApplication.ActiveDocument
For Each oSet In invDoc.PropertySets
	For Each oProperty In oSet
		If oProperty.name = sPropertyName Then
			sSet = oSet.name
			Exit For
	Next
Next
'display the property set name
MsgBox(sSet)
J-Camper
Here is an excel file, attached, with the iProperty sets and their iProperties.
Curtis_Waguespack
Hi everyone,
I might be misunderstanding the request, but I interpreted it to be asking for how to determine the property set, so that the Iproperty value can be set with the information pulled from excel, that information being an iproperty name and a corresponding value...
So with that in mind, I'll add this example too.
I hope this helps.
Curtis
'pretend this info is being pulled from Excel
sPropertyValue = "777-7777-009"
'this uses the above info to set the value for property
For Each oSet In ThisApplication.ActiveDocument.PropertySets
			'set the property value
			oSet.Item(sPropertyName).Value = sPropertyValue
			Exit For
	Next
Next
johnster100
Hi Guys,
thanks for your replies. The above suggestions worked 🙂
but they were quite slow, I found it quicker just to use a series of try and catch loops.
thanks again,
John
JelteDeJong
just an other solution (an improved version of the code of @Curtis_Waguespack ) Searching for the correct set can take time, but you can look up all combinations of set/iProperties and save it in a dictonary. Then you can use that dictonary for looking up the needed set for a property. that should be faster. see cod below.
Public Class ThisRule
    Dim setsDictonary As Dictionary(Of String, String)
    Sub Main()
        ' setup/create a dictonary wit property names that is used to look up the set names
        setsDictonary = New Dictionary(Of String, String)
        For Each oSet As PropertySet In ThisDoc.Document.PropertySets
            For Each oProperty As [Property] In oSet
                setsDictonary.Add(oProperty.Name, oSet.Name)
            Next
        Next
        Dim sPropertyName = "Part Number"
        Dim sPropertyValue = "777-7777-011"
        writeIPropertyValue(sPropertyName, sPropertyValue)
    End Sub
    Private Sub writeIPropertyValue(propertyName As String, value As String)
        Try
            'write iproperty values using the dictonary
            Dim oSet As PropertySet = ThisDoc.Document.PropertySets.Item(setsDictonary(propertyName))
            oSet.Item(propertyName).Value = value
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
