vb.net Component pattern
^_^clovis^_^
^_^clovis^_^
hello,
I'm trying to migrate the following vba macro to vb.net. I can't find the parts in (properties of) the pattern,
Any idea?
Thanks for any help
Yours
Public Sub InIam_ChromePolished()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Get a reference to the RenderStyle named "Chrome - Polished".
    Dim oRenderStyle As RenderStyle
    Set oRenderStyle = oDoc.RenderStyles.Item("Chrome - Polished")
    'a selected item
    Dim oSel As SelectSet
    Set oSel = oDoc.SelectSet
    Dim oCol As New Collection
    Dim oPart As Document
    If oSel.Count > 0 Then
        For Each oOcc In oSel
            If oOcc.Type = kDocumentObject Then
                oCol.Add (oOcc.Definition.Document)
                ElseIf oOcc.Type = kCircularOccurrencePatternObject Then
                    Dim oOccPel As OccurrencePattern
                    Set oOccPel = oOcc
                    Dim oOccEls As OccurrencePatternElement
                    Set oOccEls = oOccPel.OccurrencePatternElements.Item(1)
                    Dim oPatObject As Object
                    For Each oPatObject In oOccEls.Occurrences
                        oCol.Add (oPatObject.Definition.Document)
                        'Debug.Print oPatObject.Name
                    Next
         Next
    ' Assign the render style to the part.
    For Each oPart In oCol
        oPart.ActiveRenderStyle = oRenderStyle
    Next
    ' Force the view to update to see the change.
    ThisApplication.ActiveView.update
End Sub
JelteDeJong
I changed your code a bit for me it works now.
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
'a selected item
Dim oSel As SelectSet = oDoc.SelectSet
        If oOcc.Type = ObjectTypeEnum.kComponentOccurrenceObject Then
            oCol.Add(oOcc.Definition.Document)
        ElseIf oOcc.Type = ObjectTypeEnum.kCircularOccurrencePatternObject Then
            Dim oOccPel As OccurrencePattern = oOcc
            Dim oOccEls As OccurrencePatternElement = oOccPel.OccurrencePatternElements.Item(1)
            For Each oPatObject As Object In oOccEls.Occurrences
                oCol.Add(oPatObject.Definition.Document)
            Next
    Next
For Each oPart As Document In oCol
    Try
        If oPart.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            Dim doc As PartDocument = oPart
            Dim oRenderStyle As RenderStyle = doc.RenderStyles.Item("Chrome - Polished")
            If (oRenderStyle.StyleLocation = StyleLocationEnum.kLibraryStyleLocation) Then
                'this will fail if the render style is not localy present in the part.
                oRenderStyle.ConvertToLocal()
            doc.ActiveRenderStyle = oRenderStyle
        ElseIf oPart.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            Dim doc As AssemblyDocument = oPart
    Catch ex As Exception
        MsgBox("Error while setting render style: 'Chrome - Polished'. message: " + ex.Message)
    End Try
Next
ThisApplication.ActiveView.Update()
Jelte de Jong
Blog: hjalte.nl - github.com
^_^clovis^_^
Hello JelteDeJong
Thank you very much. After checking your version, I find out that one of my errors came from another elseIf with
ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("Open " & oOcc.Name & " to update parts..")
To see the chrome in the idw, the parts has to get the renderStyle update. So each part has to be modified. At the moment I won't develop this section as an assembly can contain some library parts which are read-only (from Vault) or different material than metal. I'll try maybe later.
in Visual Studio, after an oOcc. the only choice I had was getType.
I'm using Microsoft Visual Basic 2015 with Inventor 2020. Should I move on to Microsoft Visual Basic 2017?
again thanks for your great support.
Yours
