Adding a sub assembly component to a main assembly extrude participants
I've used code similar to this and never had a problem with it. I've added some additional code to get to a sub assemblies components and I can't seem to get it to work. I'm not sure why I get the error I do. My first msgbox returns the correct count and my second returns the correct name, so I know it's getting the component, but I don't know why it can't add it as a participant.
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim
BATCUT As ExtrudeFeature = oDef.Features.ExtrudeFeatures.Item("BATCUT") Dim EWL As ComponentOccurrence = oDef.Occurrences.ItemByName("FR END WALL LEFT WIZARD") Dim LPAT As OccurrencePattern = EWL.Definition.OccurrencePatterns.Item("BATTENS") 'MsgBox(LPAT.OccurrencePatternElements.Count) For Each LELM As OccurrencePatternElement In LPAT.OccurrencePatternElements For Each LOCC As ComponentOccurrence In LELM.Occurrences 'MsgBox(LOCC.Name) BATCUT.AddParticipant(LOCC) Next Next
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.ExtrudeFeature.AddParticipant(ComponentOccurrence Occurrence)
   at ThisRule.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
JelteDeJong
you are working with a occurence in the sub assembly there for you need to make a occurence proxy. try this:
Dim BATCUT As ExtrudeFeature = oDef.Features.ExtrudeFeatures.Item("BATCUT")
        Dim proxyOcc As ComponentOccurrenceProxy
        EWL.CreateGeometryProxy(LOCC, proxyOcc)
        BATCUT.AddParticipant(proxyOcc)
    Next
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Works perfectly, Thanks!
