FIND AND REPLACE CODE INSIDE I-LOGIC RULE
Message 1 of 19
Here is my situation:
I'm exporting my parts list and certain i properties to an excel sheet with a particular name that is the same as the dwg name so that they can be identified with one another for our MRP program. But there are multiple excel files in the same folder.  I do not want the less experienced to dive into the export rule to change the name of the .xls file just to export it with the specific name.
So does any one have an I-logic code or even vba that i can place inside the export rule to detect the generic name inside the rule and the .dwg name inside i-properties and replace it with the .dwg file name (minus the file extension) before exporting it?
Replies (18)
Message 2 of 19
awatt
First you can get the full file name.
      sFname = oDoc.FullFileName
      InStrRev(sFname, "\") will give you the integer position of the last slash.
      InStrRev(sFname, ".") will give you the integer position of the last point.
your file name is the mid$ in between.
Message 3 of 19
iProperties.Value("Project", "Part Number")
THE ABOVE IS THE WHAT I'M USING FOR MY FILE NAME. IS THERE A WAY TO REPLACE THE GENERIC "FILENAME" IN SOMETHING LIKE
ThisBOM.Export("Parts Only", "fileName", kMicrosoftExcelFormat)
AND REPLACE IT WITH THE PART NUMBER BUT THROUGH A RULE? I KNOW THAT THERE IS A SEARCH AND REPLCE FUNCTION INSIDE THE RULE ITSELF BUT I'M TRYING TO DO IT AUTOMATICALLY WHEN A NEW DRAWING IS SAVEAS'D. THAT IS WHAT UPDATES THE PARTNUMBER WHICH UPDATES MY DRAWING TITLE. IT IS TO KEEP PEOPLE OUT OF MY I-LOGIC.
Message 4 of 19
awatt
I suppose you've tried this:?
ThisBOM.Export("Parts Only", iProperties.Value("Project", "Part Number"), kMicrosoftExcelFormat)
Message 5 of 19
I just did. The problem i have with that is that it doesn't let me pick where i want to store it. I also just searched my entire computer to try and find where it would have put it and found nothing.
Any suggestions?
Message 6 of 19
awatt
I haven't messed with it much, but it may also require a path and file extension.
So perhaps somthing like this:
ThisBOM.Export("Parts Only", "C:/mypath/" & iProperties.Value("Project", "Part Number") & ".xlsx", kMicrosoftExcelFormat)
I'm not sure if the path will require foreward or back slash.
Message 7 of 19
This is my current code:
'define oDoc
oDoc = ThisDoc.Document
'specify the drawing sheet
oSheet = oDoc.Sheets("Sheet:1") ' sheet by name
'oSheet = oDoc.Sheets(1) ' first sheet
 ' say there is a Partslist on the sheet.
oPartslist = oSheet.PartsLists(1)
' create a new NameValueMap object
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'specify the columns to export
oOptions.Value("ExportedColumns") = "ITEM;QTY;M1 PART ID;PART DESCRIPTION;WIDTH;LENGTH;PERIMETER;DETAIL;Block Weight;FINISH WT"
'specify the start cell
oOptions.Value("StartingCell") = "A1"
'specify the XLS tab name
'here the file name is used
oOptions.Value("TableName") = "BILL OF MATERIALS"
'choose to autofit the column width in the xls file
oOptions.Value("AutoFitColumnWidth") = True
' export the Partslist to Excel with options
oPartslist.Export(path_and_name & ".xls", _
PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
'-------------End of ilogic ------------------------------------------------
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "M2")= iProperties.Value("Custom", "Total_Surface_Area")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "N2")= iProperties.Value("Custom", "Assembly_Weight")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "O2")= iProperties.Value("Custom", "QTY REQ'D")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "P2")= iProperties.Value("Project", "Part Number")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "Q2")= iProperties.Value("Custom", "Client")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "R2")= iProperties.Value("Custom", "Customer PO#")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "S2")= iProperties.Value("Custom", "Project")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "T2")= iProperties.Value("Custom", "Engineers Detail#")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "U2")= iProperties.Value("Custom", "DMI JOB#")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "V2")= iProperties.Value("Custom", "Operations")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "W2")= iProperties.Value("Custom", "Weld Procedure# 1")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "X2")= iProperties.Value("Custom", "Weld Procedure# 2")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "Y2")= iProperties.Value("Custom", "Delta LNFT of Weld")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "Y4")= iProperties.Value("Custom", "Shop LNFT of Weld")
The only thing That i have left is to figure out how to get the browser window to come up so i can can specify where i want to put it. I dont want the path to be in the rule because the path will change with every purchase order?
Any suggestions would help?
Message 8 of 19
awatt
It looks like you are looking for how to use the FileDialog object.  I don't have much experience with it.  Some examples came up on a search, but I didn't find much in the standard Inventor help file.  There may be more in the SDK help files.
Message 9 of 19
ANY IDEAS ON THE DIALOG BOX, AT LEAST WHAT THE STARTING CODE IS?
Message 10 of 19
You can use this code to bring up a dialog box and browse to a file. You can then derive the folder path from the file you selected.
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = oOrigRefName
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
selectedfile = oFileDlg.FileName
End if
MessageBox.Show("You selected: " & selectedfile , "iLogic")
Message 11 of 19
I will try this as soon as I can. If it works Kudos to you sir. Thank you for you time and knowledge. I twould be an excel file that i need to place, so I will try replacing "inventor.FileDialog" with "excel.file dialog". I'm gonna have to figure out where to place it in the current code, but this helps a lot. Thanks again.
Message 12 of 19
MechMachineMan
DONT FEAR, THE CODE WIZARD IS HERE.
This chunk of code will simply bring up a dialog box and ask you for which excel file you want to save to; if called in a line it will return the full file path.
Also, you may want to check if a System.IO.File.Exists(oFilePath) exists for where your first option would be to save it to, and if it does, then call the dialog box and make that your new path.
ie;
If File.Exists(oIdealSaveLocation) = True
      oIdealSaveLocation = FileBrowse(True) ' True to indicate you want to use the file to save to; False if it is just to open it.
Else
'If the file does not already exists, make it there
End if
Private Function FileBrowse(Save As Boolean)
    Dim oFileDlg As FileDialog
    ' Create a new FileDialog object.
    Call ThisApplication.CreateFileDialog(oFileDlg)
    ' Define the filter to select part and assembly files or any file.
    With oFileDlg
    ' Define the part and assembly files filter to be the default filter.
        .FilterIndex = 1
        .MultiSelectEnabled = False
    ' Set the title for the dialog.
        ' Set the initial directory that will be displayed in the dialog.
        'oFileDlg.InitialDirectory = ThisApplication.FileOptions.ProjectsPath
        ' Set the flag so an error will be raised if the user clicks the Cancel button.
            .CancelError = True
        ' Show the open dialog.  The same procedure is also used for the Save dialog.
        ' The commented code can be used for the Save dialog.
        If Save = True
            .Filter = "Excel Files (*.xlsx)| *.xlsx"
            .DialogTitle = "Specify New Save Location and Name"
            .ShowSave
            Else
            '.Filter = "Inventor Files (*.iam;*.ipt;*.idw;*.dwg)|*.iam;*.ipt;*.idw;*.dwg|All Files (*.*)|*.*"
            .DialogTitle = "Select Excel File To Use As Drawing List"
             .ShowOpen
'    oFileDlg.ShowSave
    End With
        MsgBox("Error Exists")
   ElseIf Not oFileDlg.FileName = "" Then
        Dim fNames As Object
        fNames = Split(oFileDlg.FileName, "|")
        Dim curName As Object
        Dim lstSource As Object
        For Each curName In fNames
            lstSource.AddItem(curName)
        Next curName
Return oFileDlg.FileName
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 13 of 19
This code keeps telling me
"All other Sub's or Function's must be after Sub Main()"
What does that mean?
Any chance you can help me inplement this in my current code to export everything that i need but specify the location where i want to save it?
Message 14 of 19
MechMachineMan
It means your whole rule needs to look like:
Sub Main()
      ' Put your code here
End Sub
Private Function oFileBrowse
'Function code here
End function
'Additional functions here
Justin K
Message 15 of 19
OK This is what i have. It's My code included with yours, but it's not bringing up the dialog box to save. it does however still save my stuff. but it doesn't allow me to pick the location i want it to save to.
The "oPartslist.export" part of my code is how it saves. I'm still new at vba so i dont quite fully understand what your caode is telling me. Or how it working in conjunction with mine. Any thoughts?
Sub Main()
'get the path and name of the drawing file
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
'define oDoc
'-------------Start of ilogic ------------------------------------------------
oOptions.Value("ExportedColumns") = "ITEM;QTY;M1 PART ID;REV;PART DESCRIPTION;WIDTH;LENGTH;PERIMETER;DETAIL;BLOCK WT;FINISH WT"
oOptions.Value("ApplyCellFormatting") = True
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "L1")= "Total Surface Area"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "L2")= iProperties.Value("Custom", "Total_Surface_Area")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "M1")= "Total Weight"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "M2")= iProperties.Value("Custom", "Assembly_Weight")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "N1")= "QTY of Assemblies"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "N2")= iProperties.Value("Custom", "QTY REQ'D")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "O1")= "Tag#"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "O2")= iProperties.Value("Project", "Part Number")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "P1")= "Customer"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "P2")= iProperties.Value("Custom", "Client")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "Q1")= "Customer PO#"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "Q2")= iProperties.Value("Custom", "Customer PO#")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "R1")= "Project"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "R2")= iProperties.Value("Custom", "Project")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "S1")= "Eng Det#"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "S2")= iProperties.Value("Custom", "Engineers Detail#")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "T1")= "DMI JOB#"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "T2")= iProperties.Value("Custom", "DMI JOB#")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "U1")= "Fabrication Operations"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "U2")= iProperties.Value("Custom", "Operations")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "V1")= "Weld Procedure #1"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "V2")= iProperties.Value("Custom", "Weld Procedure# 1")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "W1")= "Weld Procedure #2"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "W2")= iProperties.Value("Custom", "Weld Procedure# 2")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "X1")= "Delta Total LNFT of Weld"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "X2")= iProperties.Value("Custom", "Delta LNFT of Weld")
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "X3")= "Shop Total LNFT of Weld"
GoExcel.CellValue(path_and_name, "BILL OF MATERIALS", "X4")= iProperties.Value("Custom", "Shop LNFT of Weld")
End Sub
    With oFileDlg
        .FilterIndex = 1
            .CancelError = True
        If Save = True
            .ShowSave
            Else
            '.Filter = "Inventor Files (*.iam;*.ipt;*.idw;*.dwg)|*.iam;*.ipt;*.idw;*.dwg|​All Files (*.*)|*.*"
             .ShowOpen
   oFileDlg.ShowSave
    End With
        Next curName
End Function
Message 16 of 19
MechMachineMan
Sub Main()
'define oDoc
If File.Exists(path_and_name & ".xlsx") = True
      oSaveLocation = FileBrowse(True) ' True to indicate you want to use the file to save to; False if it is just to open it.
Else
End if
oPartslist.Export(oSaveLocation, _
End Sub
    With oFileDlg
        .FilterIndex = 1
            .CancelError = True
        If Save = True
            .ShowSave
            Else
             .ShowOpen
   oFileDlg.ShowSave
    End With
        Next curName
End Function
Justin K
Message 17 of 19
I get the following error message:
Rule Compile Errors in Export properties to Excel for M1, in Delta Titleblock Template.dwg
Error on Line 41 : 'Exists' is not a member of 'Inventor.File'.
Message 18 of 19
MechMachineMan
System.IO.File instead of just File then.
Google msdn + vb.net.
It is your friend for all things iLogic programming.
Justin K
Message 19 of 19
The following pics is what i'm trying to accomplish.
When you right click on the Parts List it gives you the option to export. Click on that "Export" word and this Dialog Box pops up to choose where you want to save your export file.
What is the code to make this box come up? Where do i insert it or what do i change in my code for this to happen? The Options button you see is the Code of "oOptions" you see in my code. I just want to be able to choose where i want to save the exported file.
