Fillet Rename
Fillet Rename
Fillet Rename
Hi all
I was like a kid to VB programming... and i copied one of the program from this forum for renaming fllets... But it was always giving an error...
So can any one help me out from this please...
Sub changeFilletname()
    Dim ptDoc As PartDocument
    If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
        MsgBox "please open a part document"
        Exit Sub
    End If
    Set ptDoc = ThisApplication.ActiveDocument
    Dim Fillet As FilletFeature
    Dim j As Integer
    Dim prefix As String
    prefix = "Fillet_"
    j = 1
    For Each Fillet In ptDoc.Feature.FilletFeatures
        Fillet.Name = prefix + IIf(j < 10, "0" + CStr(j), CStr(j))
        j = j + 1
    Next
End Sub
Hi ,
You need to use part component definition to get all features.try this
Dim ptDocDef As PartComponentDefinition
Exit Sub
End If
Set ptDocDef = ptDoc.ComponentDefinition
Dim j As Integer
prefix = "Fillet_"
j = 1
For Each Fillet In ptDocDef.Features.FilletFeatures
j = j + 1
Next
End Sub
Thank you very much :)....
I just want to know, Whether it was the same way by which we have proceed to rename work planes also...
Becasue i tried to change the code with respect to work planes... the code works fine for counting number of work planes but it was giving error to rename the work planes...
Can you please help me out in this also....
Sub changeworkplane()
        Exit Sub
    End If
    Dim WorkPlane As WorkPlanes
        Dim j As Integer
    prefix = "Work Plane"
    j = 1
    MsgBox ptDoc.ComponentDefinition.WorkPlanes.Count
      For Each WorkPlane In ptDoc.ComponentDefinition.WorkPlanes
    WorkPlane.Name = prefix + CStr(j)
        j = j + 1
    Next
End Sub
Hi ,
As i told you earlier ,still you are missing PartComponentDefinition here.It's fine .Understand this example..
    Dim planName As String
    Dim workPlaneType As Boolean
    Dim WorkPlane As Inventor.WorkPlane
    Dim i As Integer
    Dim j As Integer
    i = 1
    j = 1
        Exit Sub
    End If
        prefix = "MyPlane"
For Each WorkPlane In ptDocDef.WorkPlanes
    Set WorkPlane = ptDocDef.WorkPlanes.Item(j)
    planName = WorkPlane.Name
    workPlaneType = WorkPlane.IsCoordinateSystemElement
    If workPlaneType = False Then
      WorkPlane.Name = prefix + CStr(i)
      i = i + 1
    End If
    j = j + 1
Next
End Sub
Thank you Prakash... It was so kind of you to explain in detail :smileyhappy :
One last question... Actually i was not understanding the concept of Grouping..
For Example Fillet is grouped under Component Defintion --- Features --- FilletFeatures (Which has been called while Renaming)
and Work planes are grouped under --- Component Defintion --- workplanes
Likewise if i want to find out some thing else like facedraft or sketches.. is there was any simple way to do . I was using View--Objectbrowser to findout but i was not sucessful every time.
So.. It would be helpful if you can guide me in this also. Sorry if iam asking so many questions...
