Monitor parameter change
Is there a way of monitoring for parameter changes and then running subroutines or other things based on the change, like:
If HouseColor *changes* Then
   Call PaintHouse()
End IF
 I'm looking to do this for a multi-value string parameter thats in a form as a combo box.
Preferrably I would like to see this done without any external files as I am trying to create a .ipt that contains everything for the thing I'm working on.
Is this possible?
adam.nagy
Autodesk Support
Autodesk Support
I've written a blog post which should be of help:
http://adndevblog.typepad.com/manufacturing/2014/11/get-notified-about-parameter-change.html
Cheers,
Adam Nagy
Autodesk Platform Services
Thanks for the input, what you did in the blog post looks great, but my rule is very complex with 20+ parameters, so I dont think I can use your method.
Is it possible to use ModelingEvents.OnParameterChange to monitor specific parameters, or is it the global "Any parameter change" check?
Thanks!
adam.nagy
Autodesk Support
Autodesk Support
It is global, but there you'll get the parameter that changed as an input parameter:
Event OnParameterChange(DocumentObject As _Document, Parameter As Parameter, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, HandlingCode As HandlingCodeEnum)
Adam Nagy
