FilePropertySets - Iterate through all of the documents referenced by the assembly - ModelStates
Marcus_Chong
Marcus_Chong
I am trying to link up the value of filepropertysets from assembly to all other referenced documents. And at the same time, avoiding reference document that is ipart or library files. Some of my sub assemblies and parts are done with model states.
Is there a way to do it?
My code looks like this, but it is not working. is there anything that i have missed out.
Sub Main()
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oRefDocs As DocumentsEnumerator = oDoc.AllReferencedDocuments
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
	oRefDoc.FilePropertySets.Item(3).Item("Project").Value = iProperties.Value("Project", "Project")
Next
End Sub
Please advise.
bradeneuropeArthur
Try it this way:
Sub Main()
Dim oRefDoc As Inventor.Document
Try
	Catch
	End Try
Next
End Sub
Arthur Knoors
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Marcus_Chong
That works perfectly!
Thank you Arthur for your great help!
